- Replies 7
- Views 3k
IBMobile 2 posts
jbremount 1 post
Texas CTD 1 post
diesel4life 1 post
I have a Isspro mechanical fuel gauge in my truck. I never got around to hooking up the light for the gauge. I very rarely drive the truck at night. The question I have is..there are two prongs on the back of the gauge. Does it matter which one is the hot and which one is the ground? Neither of them are marked with a + or - sign. Also, I am wondering if you guys have had good luck using "add-a-fuse" connectors? FP gauge is the only after market electrical accessory I have on the truck. I was thinking of using the add a fuse connectors to get a power source out of the panel. Wondering if you guys have had good success using those?Or if I should use another way to splice and get power for the light.
Thanks.
