I have a 2201 3500 with 24v. I have an antifreeze leak that is showing up in the passenger wheel well. There is a 2" spray pattern all the way across the liner like the tire is spraying it up there. The engine compartment is dry. There is 1 steel line that runs across the fender in the engine compartment but all connections or joints are dry. Although I have not removed the foil tape that is on them, but no signs of leaking or water marks. Could the heater core be leaking? If it was would it be wet in the cab or shouldn't I smell it? Any and all thoughts appreciated.
  • Replies 35
  • Views 11.1k
Are you losing a ton of coolant all the time? Like having to top it off a bunch? I would hose down the block and start looking around the freeze plugs like Diesel4life said. Maybe one is rusted through. Had that happen on my old ford 390 one time.
Your best bet would be to use a pressure washer (car wash) and CLEAN the side of the block real well. Then you should use the pressure tester and see where the leak is. This isn't a "53" block, is it?
I don't need to clean the engine compartment or the block. It is spotless. I mean I would eatoff it. Everybody seams to get off topic ordoesnt read the entire post. No leaks in engine compartment. No smell in cab. Only sign is in passenger side wheel well liner where the liner meets thefender.  It is notalot of leakage. I haven't topped it off since I have noticed it.
I read your post from start to finish. Everybody has already mentioned all the obvious and it didn't seem to satisfy your search, so I was simply throwing out other ideas. We can only do so much to help sitting behind a computer screen.
Check the lower right corner of the radiator. That is the only other place it could be coming from.
  • 4 weeks later...
Well I think it is my ac evaporated. Still have not been able to pin point the leak source but that is the only thing left. Anybody know of a sure way to tell if that is the problem before taking the dash apart? I watch mopars video and it doesn't look fun but not paying the stealer 1000+ to do it.
Edited by rseabur
Easy way to check for leaks is to go get a can or two of 134A and the hose to put it in. Put one can in your A/C and then get a spray bottle and mix up some liquid dish soap and water. Mix it a bit rich on the soap. Go spray your A/C lines and look for bubbles. If it is a small leak you may not find it right away, but the place it is leaking will blow a bunch of bubbles. Keep in mind that the bubbles caused by a leak will all be the same size. If the bubbles are just random sized then it is not a leak.
If the fluid is neon green then i would check the A/C system on the passenger side fender is the A/C filter the big black canister looking thing right in front of the PCM. I have seen them leak and cause a pin hole that you will only see when the system is pressurized ie when the engine is running and the ac is on blowing cold. The A/C system runs when the heater is on but not as much as when the cold is on.
Well my dad and I were looking at this supposed antifreeze or what I was leaning toward ac oil leak yesterday. He did not think it was either. Thought it was to thick. When I parked the front tire was in a position to where we could see a NAIL in it that was leaking....My thoughts...Original owner got a flat knowing he was selling truck. He either put that tire slime or fix a flat in tire to save from repairing the tire which it did. 1yr later the temporary repair has started to fail sparying the green whatever it is out of the tire. Looks like you NAILED it Dieselfuture. Thanks to all for all the help. Will find out for sure if that nail has been the problem when I get to the tire shop next Saturday.
Well, pull the nail and confirm it!
Got the nail pulled today. The tire was filled with that slime stuff that they use to fix holes. Haven't got all the stuff sprayed off yet but think i am good to go with this problem. Just glad I didnt pull the dash to do the heater core and evaporator. Now its a brake job and trying fix sticking front calipers. Thanks for your input guys
