I replaced my water pump last year. It is leaking out of the weep hole again. The thing is when I was trying to check I didn't see anything come out of the weep hole. I could see where it had leaked out of it, there was evidence of it at the weep hole. There Is antifreeze under the pump that pooled there. But when I get the truck to temp and watch it I never saw any leak.Would the pump just leak intermittently? It just seems to me if it is going bad it would leak all the time. Is there anything else that would cause it to leak from the weep hole besides the pump goin bad?My truck is a 2002 6 speed 4x4 Thanks to anyone that can helpJason
