- Replies 15
- Views 3.8k
mopartechnician 4 posts
dripley 3 posts
diesel4life 2 posts
rancherman 2 posts
not only is there cheapo and high end ball joints available, but there is a choice of 'adjustable' caster/camber +/- 2-4 degrees.
How in the heck would I know what I'd need, UNTIL new joints are installed??? There is no way I could get anywhere close to 'true' reading as shot as my current joints are! Is there a common problem on these dana's that an automatic 2 or 4 degree adjustment will correct?
Or are these offset joints for the lifted guys...
I am assuming they are only adjustable as to the way they are pressed home... after that, you have to drive em out and clock em to the right spot..... right??
