- Replies 14
- Views 2.9k
ISX 4 posts
Lone Watie 4 posts
Hood Latch 3 posts
Mopar1973Man 2 posts
Just wanted to show my cheap winter front <$20
1. Thin sheet of sheet metal from Home Depot for $9 (got the one in the ducting department which had cardboard around it (which I used for the template)
2. Duct Tape
3. 2-sided carpet tape
Used duct tape on the grill front to provide a good base for the 2-sided carpet tape (by the way, the duct tape by itself probably provides enough barrier, but doesn't look as good). Cut out the sheet metal using some cardboard for a template. Trimmed best I could to fit the openings with the sheet metal shears. Put the 2 sided carpet tape on the back, peeled it and stuck it on. Don't know yet how it will bear in the elements, but will find out next week as Northern AZ is expecting some good snow fall. Only had one mishap on the lower right, accidentally pushed the corner of the grill in too much because the front piece wasn't quite trimmed enough.
