Fuel Pressure And Hydraulic Buzzing?
- Replies 18
- Views 4.1k
Kotta390 6 posts
diesel4life 3 posts
Ilikeoldfords 3 posts
KATOOM 2 posts
It has been awhile since I posted about my cracked 55 block. I have that band-aided for now and it mostly holding up.
I have however been experiencing some strange phenomenon with my fuel pressure. When It is cold outside <35F, my fuel pressure is around 15.5-16.5psi at idle and when I drive the truck a good ways, it will creep up to around 17-18 at idle which is fine. The other end of the spectrum is when it is warm outside. >75F, the fuel pressure will be around 18.5-20psi at idle but never really goes above that. I have the AD150 and full big line kit along with a needle valve. Sometimes the fuel pressure fluctuates a little but it is slow and the gauge doesn't go crazy, it is a very clear and slow movement. Any ideas?
Second issue is when it is less than <35F, the hydraulics or what sounds like my power steering and braking system has a loud buzzing noise when first cranked up and the warmer the weather gets or the harder i drive it in the cold, the buzzing goes away and I never notice it anymore. The breaks and power steering are not affected by any means but it is loud on cold mornings. What is going on here?
Thanks for all of your help.
