Front Brakes Draggin' Me Down
- Replies 17
- Views 3.7k
Rebelrodder 7 posts
joecool911 5 posts
MnTom 3 posts
diesel4life 1 post
Howdy!
I'm having some brake drag coming from the calipers in my truck. Here's a little background on how I got here:
Worn out ball joints started me down the rabbit hole of a front end rebuild. I've got new ball joints, hub bearings, rotors, brake pads, track bar and steering box brace. The good news is it drives about like it should tho new TREs are in the near-ish future. That should finish things up and make it all good under there. I changed the pads and rotors because they were old and thin and the truck had started pulling to the left under moderate braking. Hard braking was straight as an arrow. Go figure...
After I installed all this new hardware and took it for a test drive, I came home to a lovely face full of hot brake smell. Investigation showed that the calipers were dragging on both sides but the right side was worse. The calipers got new rubber bushings and lots of fresh grease on the guide pins when the pads were installed. I tried bleeding at the calipers only to find that the bleeder was rusted shut down in the caliper bore, so..... off to the parts store for some fresh reman'd calipers and the flex hoses that feed to them.
I bled the front part of the system carefully, I know there is no air in there. The rub (literally) is that the calipers don't seem to be releasing very much. They do loosen up when the brake pedal is released and the drag on the rotor is light but, it is still there as is evidenced by what i feel like is excessive temperature on the hub flange where the wheel mounts. After a 12 mile trip to work I can hold my fingers on that lip on the hub. The right side is warmer than the left and I don't burn my finger tips but it does seem warmer than a bearing should get. That's part of why I'm chasing root causes of brake drag. As a further complication, the left pull under moderate braking is back though it is less dramatic than it was before.
I've done some digging on various forums and the main causes people seem to find are the flex hoses going bad and the calipers sticking on the guide pins or the anti-rattle springs. I'm thinking that I can bypass the hose part since mine are new. I'm pretty sure I don't have any anti-rattle springs because they don't seem to exist on 99's with single piston calipers. They weren't there to take off and didn't come with the new calipers. I've read that the calipers should slide easily on the guide pins but mine do not. They barely move at all even though there is plenty of evidence of grease on the pins and hopefully in those rubber(?) bushings. Should the single piston calipers move easily on those pins? I don't see how they could since the bushings fit so tightly on the steel pins that the caliper bolt goes thru. If they are supposed to slide on there, how do you keep the grease in there to lube it? Anybody have suggestions for that?
This weekend I'm going to do a complete brake system flush and bleed in the hopes that my issue is really hydraulic in nature rather than sticky guide pins. I'm hoping it is as simple as some debris being pushed up out of the crapped up caliper and blocking some port or other in the metering block/proportioning valve. I'll keep an eye out here of suggestions and post any solutions I might find.
Thanks for reading my novel!
Jerrod
