Injectors = Higher MPG?
So I've been searching the forums and ran into a few topics about some aftermarket injectors will not only give more hp/tq but also increase fuel mileage. One of these injectors are the rv275s. I see they are good for about +40hp/80tq over stock injectors and somehow get better fuel mileage?
Are there any other injectors that do the same and how does an injector which can supply more fuel give better MPGs? I am a little lost on the theory of this. If the engine requires "X" amount of fuel at the rpm and load..how does a different injector give better fuel mileage when it is producing the same "X"?? Is it the spray pattern? School me please :)
  • Replies 33
  • Views 13.1k
All this assuming your going to drive the exact same way you did prior to getting the extra power...most people don't.
The 275s are a nice bump in power but I have been thinking about upgrading to something more.
As for the Smarty, it has been confirmed by sources at MADS that they will be releasing UDC for the 2nd gen crowd. Should be interesting to see what they come up with considering what they have done with the third gen crowd.
Yep, I agree here too... If you are 'making' or requiring an extra 75 horse... there's no way
your going to 'up' your economy. It takes something on the order of ~ 4 gallons per hour to make
EACH additional
100 horsepower (continuously)
.......which should be around 3 gallons EXTRA per hour to maintain your 75 horse increase.
Sorry, but physics are physics.
Now, I'll agree with Mikes explanation of how these new injectors will clean up via smaller droplet,
(the faster injection time plus the finer droplet size) helps a little with efficiency with THAT
INCREASE of fuel... but it's still an increase!!
it's when you go back to 'cruise mode' is where the increase in mpg will be seen.
For me, and just about any other 'boy' in here, keeping the foot out of it for the next oh, 10,000 miles or so, would take a herculean effort!! :)
Edited by rancherman
DAP uses Bosch bodies, rebuilds them, does a bit of extrude honing (I THINK) & them flow matches them with high pressure fluid, rather than low pressure air. It's a fine process, as Jacob described all that goes into it. They also have "Aftermarket" injectors with no core charge, but I doubt they go through the same process. One thing to remember, with your HO pump, you will have a bit more timing advance, so use lower timing levels on the Smarty. 50-75 HP injectors seem just what you need. If you EVER plan on upgrading the turbo, just go for 75-100 HP now to save the future investment.
Ed
How will I be able to lower the timing on the smarty? I think it either adds timing or doesn't. Do larger injectors require less timing?
I got the rv 275 I like the small increase in power and gained 1.8 mpg when I don't play with  the extra power. I use a boost elbow and fooler so that my boost is max 29 lbs. I happy with the setup for now, maybe later will change.
What is being suggested is that you don't go crazy with the smarty and jack the timing way up.
If you read the book, either odd or even has or doesn't have timing added. I THINK you are safe with even numbers. CHECK FIRST !!!
Ed
Either way all modules add timing of some sort. But where and when the timing is added is the problem. Edge Comp seems to add the timing down low RPM's. But not a 100% certain either.
The Smarty S03 allows you to change the timing setting by selecting settings between 1 and 4.
So you can select the Catcher number you want and then you can select something like 'make adjustments' and then set the timing settings between 1-4.  I think 4 is the highest timing setting.
I run an S06 but on the S03 I believe the timing setting of 1=stock, 2=advanced, 3=moderate and 4=greatest.
That is something that frustrates me about modules. I which they would explain there timing curve a bit more. Smarty seems to have setting that aren't explained very well. Kind of like the duration setting. Even Edge Products are just as bad.
Well I am on Catcher #5 so, adding injectors I need to possibly lower the timing? I need to play with the settings some but when I hear adding injectors and then all of a sudden I need to watch timing, that doesn't really mean much to me??
It has been a while since I even plugged my Smarty in but I am running #7 with timing set either on two or three. I had my smarty before I installed my injectors and never changed my settings, but I also have an SO pump. I'm not sure what the difference in timing is between the two but I would think it's irrelevant because the Smarty changes those parameters anyway. Brian from Smarty hangs around here once in a while, he would be the guy to ask. You could probably shoot him a PM.
In general adding timing (as compared to stock timing) will help with mpg's.  In the Smarty programing I believe that each level of Catcher (default mode) will add higher timing levels.   For example (I made these numbers up for illustration only) Catcher 3 with the highest timing level may have timing at 15 degrees advance, Catcher 5 may have 17degrees, Catcher 7 may have 19 degrees and Catcher 9 may have 21 degrees.
My personal experience is that timing may need to be adjusted down if you are towing heavy (to help control egt's etc) but if you are not heavily loaded advanced timing will help with mpg's.  If you drive your truck hard and maybe race with it, highly advanced timing will generate more heat and can go to the extreme and melt pistons etc.
Guages can help you monitor your operating conditions so that you don't abuse or cause harm to your engine.  As an example I have 50hp upgraded injectors and I run on Catcher 9 with the most advanced timing I can get and get the best mpg's (22+ hand calculated on a CR).   I also have guages so I know the operation conditions of my engine.  I don't drive with a heavy foot and don't use the raw power of Catcher 9 (+ 210 hp) but take advanced of all the other tuning parameters that Catcher 9 provides my engine.
So if mpg's is your goal and you don't drive your truck hard, then try changing the timing level in Catcher 5 and see if you can see a difference in any of the settings and just monitor the operating parameters of your engine.  I would even try the higher levels of Smarty and do the same thing to find out what works well with your truck.  I don't know what kind of tranny you have in your truck but if it is an auto just know that a heavy foot in the higher levels of Catcher will fry an auto if it is not built for the power.  Just because you run level 9 doesn't mean you will wreack your transmission.  It's all in the discipline of your foot.
I have a NV5600. I am out for MPG more than anything. I guess I will have to play with it some
The HO pump already advances the timing somewhat, try to keep the Smarty timing lower than an equivelant SO truck would use.
Ed
