So... I have a bit of a project..
Well I started tearing into the repairs needed for the new rig before it is Camp/Road Ready...  I have my work cut out for me but, tis ok and will be well worth the effort :thumb1:
 I will need to add a place for some deep cycle batteries as this rig is not fully equipped.. I tore the cabinets and paneling out today... I will also be giving the walls a fresh coat of paint... Stay tuned!!!post-1978-0-57704300-1395804305_thumb.jp
post-1978-0-99306300-1395804323_thumb.jp
post-1978-0-78445100-1395804339_thumb.jp
post-1978-0-23901600-1395804383_thumb.jp
post-1978-0-40997000-1395804425_thumb.jp
post-1978-0-58391600-1395804461_thumb.jp
post-1978-0-49551700-1395804502_thumb.jp
post-1978-0-29397600-1395804601_thumb.jppost-1978-0-29397600-1395804601_thumb.jp
post-1978-0-46424300-1395804562_thumb.jp
  • Replies 69
  • Views 14.8k
Yes, 80psi and the reviews I read sounded pretty good... I posted 1 link to some of the reviews on the tire but I had also seen some good comments on some RV forums as well..
Did you have to upgrade wheels? Or were your OEM tires LRE??
Just don't see a lot of 80 psi OEM 15" wheels.
My original tires were only load range D.... But I wanted to upgrade to E and I used the same wheels...
6 lug, might be 16" wheels. mine had load range D on it, had Maxxis LRD's from 09 one bubbled and i went to cooper LRE.s tows so much better now too.  i don't air up to 80, i keep them at 70.
My six lug 15" rims were only pressure rated for 75PSI if I recall. That is with the rubber valve stems, but I can't say I would trust the rubber stems at that pressure. The only 225/75/R15 in LRE that I know of is the Maxxis tire, but it is still an ST tire.
Question... HAve you ever seen the installers grab from a different pile of valve stems when installing our E rated tires??? I haven't either... nor had I thought about it till you mentioned the valve stems here Tom... I will say the spare has a metal valve stem... had them keep that one as long as it was good!!
http://www.treaddepot.com/group/glst.html%C2%A0%C2%A0.html
6 lug 15"
5 of my 6 lug 16's are rated for 65 psi, and one of them is rated for 80 psi. Most OEM 15" 6 lug trailers wheels I have seen are only rated for 65 psi, so it appears you got lucky.
There are rubber valve stems rated for 80 psi.
http://www.treaddepot.com/group/glst.html  .html
Many tires stores only stock the high pressure stems, it keeps the wrong ones from being installed.
The pressure charts I find say the rubber stems are rated for 65 PSI. I put the next higher stems in my rims when I mounted the tires.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=208
Standard ones are, but there are high pressure ones... That link even shows them, 80 or 100psi versions. I recall seeing them without an exposed brass barrell.
My pickup came OEM with rubber and a door sticker calling for 75psi.
The low psi ones will supposedly blow out at 80-90 psi, which is obtainable with a load on a hot day at 75-80 psi cold.
