- Replies 12
- Views 3.1k
InjectableAddict66 5 posts
mopartechnician 2 posts
mulcher812 1 post
rich 1 post
Ok guys new to the forum and looking for some help.
First off ill give some background.
2001 3500 QCLB DRW 24v 6 speed 4x4
Bought the truck about two weeks ago as a NY salvage after wrecking my 99 2500 QCLB 24v 6 speed 4x4
New truck had a dash fire due to supposedly the blower mounter shorting and catching fire. So I stripped the interior completely. The only thing used from the dually was the power door lock motors, power window motors and the power seats. Ii changed every nut, bolt, washer, clip, and harness and hooked up right at the fire wall. All in all the interior swap went smooth with no hiccups or cus words. Buttoned up the interior and now it's time to test all components and still everything goes smooth to my surprise. Now it's time to start the truck. After testing relays fuses and resetting the APPS I crank her over and crank and crank but nothing. I had already checked fuel pressure to the IP so I cracked #1 injector line and nothing. Cracked the rest of the lines and #3 only one squirting. A disappointment but not a loss as the IP in the 2500 only has 3k miles on it so I change the pumps out bleed the lines and try to get her started still non fire without starting fluid bursts and will quickly die.
This is where I'm at I have checked.
Fuel pressure
IP voltage = 12.2 volts with key on and cranking
IP continuity to ground
Fuel shutoff has no power with key on or cranking
Cleaned all grounds I know of
Bleed all injectors except #2
Dumped power for 24 hrs reset everything tried again
Truck also has airdog 2 running at 21lbs even when cranking via test gauge in engine bay watching while cranking
Only code I have is P0230 which I know is transfer pump circuit out of range but I didn't think that would cause a no start in my case
Any help would be appreciated I'm willing to do more tests but I'm out of ideas so I figured I'd ask the cummins gods here
Also sorry of the lengthy post I'm just trying to cover my bases
Thanks
Gage
