Baby got new shoes....
Yabba got new shoes today :thumb1:  Went with the Firestone TransForce HT post-1978-0-95295600-1402109098_thumb.jppost-1978-0-01557400-1402109101_thumb.jppost-1978-0-95246400-1402109102_thumb.jppost-1978-0-15711600-1402109105_thumb.jp Only took 3 tries to get the steering wheel straight... :doh: post-1978-0-37033400-1402109107_thumb.jppost-1978-0-29143600-1402109109_thumb.jppost-1978-0-29066900-1402109111_thumb.jp And then got a bath when we got home...post-1978-0-95446300-1402109112_thumb.jp Should be good for a few years :cool:  Next project, Injectors :thumb1:
  • Replies 31
  • Views 5.8k
Explain please.
Pretty straight forward. They either get the steering wheel straight when the alignment is done or they don't get it quite right the first time.
The collar on the drag link has a single bolt that clamps it tight loosen it up and turn the threaded collar in one direction or the other to center the steering wheel and retighten the clamp bolt. Eazy peazy, just need to fiqure out which way to turn the collar, never need to go more than 1/2 turn to recenter the steering wheel if its 1/4 turn or less off center.
If the tire shop does it after it is not right and I take it and leave to find it off then go back and tell them then 1/2 hour goes buy they test drive to confirm then another 1/2 hour to get in in and reaqdjust and then retest drive to make sure and then maybe readjust. Me just going home and making the adjustment takes about 10 minutes at most if I have to make a couple attempts.
I didn't know to explain it. first off my truck has never seen a alignment ever. But when I would change parts like track bar and ball joints it moved a bit off center so I do just as W&F said twist the drag link a bit (1/4 turns) and test again. Straight as arrow now.
simpler than  pulling the  steering wheel and  re clocking it!
Edited by rancherman
Be glad you don't have the same steering set up as I do. In order to change the steering wheel position I need to tighten one tie rod and lengthen the other. It is still esay to do, but more of a pain.
They look "real purdy" Yabba!!! :duh:  :cool:
Edited by dorkweed
Yep the 2wd,s are a bit different, one instant where a 4wd is simpler.
Just think of the fuel mileage increase if you did have your truck aligned!!!! :duh:  :cool:  :hyper:
Aaaahhh... Aligned? 4WD can only have the toe set. Don't have any tire wear problems so... I must be really really close.
Isn't the    4 link  control arms   set  via   eccentric bolts.    which sets the squareness-to-the-frame..     it's more of  a   one time deal at the factory,   but certainly  can change  with wear/butt load of miles,
and  of  course  the   various  - or +   degree'd  ball joints  for   setting   castor/camber..  ( I still don't  know  why  they are offered!...  ia  there  an inherent problem from the factory? )
Probably  neither one of these  would affect  fuel economy much,   as long as   the  fronts   aren't plowing down the road,  Like mike said.    only    handling and  tire wear...
How many  Fords  have we witnessed  'dogtracking'  down the road  in the  past  30 years?    It's   not cool  when  a person can see the  hubcaps    on one side of  the  vehicle  directly   in front of them!
Well I finally got the truck aligned properly yesterday :hyper:  :hyper:  The steering wheel is pretty darn straight too :hyper:  :thumb1:   I went to a different Tuffy Auto up in Land O Lakes, and when he put it on the Alignment Rack and looked at the screen .... All that came out was a "OH BOY :doh: " and a sigh...  I said to the guy he made a lot of work for you didn't he?? He lowered his head and said YES :duh:   Anyway, Yabba is now walking a straight line and the steering wheel is straight :thumb1:post-1978-0-45811300-1403365444_thumb.jp
Just got around to doing this adjustment today after rotating my tires and greasing up the front end.  It is really easy.  Took longer to test my adjustments driving around the block after each of three tries.  Thanks again!!!! :thumb1:
