Addiing 12 volt to frige operation
- Replies 4
- Views 2.1k
Mopar1973Man 1 post
MnTom 1 post
AH64ID 1 post
joecool911 1 post
My Dometic refrigerator runs on either 120V or propane. What would be the procedure to add 12 volt? I assume it would be easiest to use a converter to run off batteries. How would I switch over to 120v if I plug it into a converter? Or would I simply run off batteries through the inverter when hooked up to shore power? How big of a converter should I consider?
Seems like a good feature to have 12 volt operation while driving.
