- Replies 11
- Views 5.1k
68AMXAMC 4 posts
Mopar1973Man 2 posts
mopartechnician 2 posts
YabbaDoo 1 post
Hi everybody, my first question on Mopar1973Man.
I have a stock 2001 Dodge 24v . In Jan.2012 had a lift pump failure & cooked VP44. Replaced with rebuilt VP44,and a Air Dog 150. About a month ago started to have a problem with hot starts, would start and stall.
I only had the idiot light for the fuel pressure warning, never came on. Problem continued to get worse. Bought a real fuel pressure gauge and discovered I had 13lbs. at idle and would drop below 10 lbs. any thing above idle, replaced filters, both were only a month old, no change. So I put the 17lb spring into the Air Dog that came with the pump. Now I get 15lb at idle , and the pressure drops to 13lb anything over idle. WOT will cause a drop below10lb.
Called Air Dog and they are sending a new pump, still waiting for the UPS to deliver. I have codes P0122 and 1689. I am doing the tests listed by Mopar73man for these codes tomorrow.
Truck runs strong when cold, even at these fuel pressures, but as soon as it reaches 160 degrees the stalling and hard starts return. Removed thermostat helped some, but I live in central Florida, and everything is hot here
I think the VP-44 is on its way to death.
Any suggestions ?
Thanks Sam Y
