- Replies 9
- Views 4.6k
Mopar1973Man 3 posts
Nekkedbob 2 posts
MnTom 1 post
ISX 1 post
I have a 98.5 4x4 5 speed that is box stock truck with 200k miles and was wondering what the max boost would be if I put a boost fooler and a boost elbow or just capped of the waste gate line. I am not looking to make goobs of power but wondered if I will see any power increase or if it will hurt my engine in any way . From what I learned many years ago as a owner operator the more air with the same fuel rate would drop the EGTs. I have installed a full set of gauges and will be ordering a Fass DDRP in a week or so. I can get a max of 20 PSI at wot before it defuels or opens the waste gate or both and if there is any more power to be had I would to be able to use it if needed. I don't want to by a comp if I don't need one. I will be going on a trip in Sept with a small trailer and it will be the determining factor. My trip will be at least 3 weeks and cover close to 6k miles so the truck needs to be rock solid reliable
