Frantz oil filter
I want to install a Krantz paper tissue filter on my 2002 5.9 diesel dually. Can anyone tell me if the plugged second hole on top of present oil filter housing can be used for oil supply to the Krantz. I plan on using the oil filler cap with mod to return the oil to the engine. Any info on this topic would help Thanks Tom
  • Replies 26
  • Views 8.9k
I know this is an old thread but I have a question on the Frantz. I have one which is going to be installed hopefully this weekend. I know to get the hose on the barbed fittings the big guy said to boil the ends of the hose in water but I was wondering if I could use a heat gun to soften them up to slide them on?
Yes it can... Here is photos of my setup...
When you do the oil cap mod make sure you take your time and file down the old tab in side the cap. Also make sure you drill the hole center to the cap... Also your going to need a small die grinder to file those tabs back... I didn't... So basically I got to redo my oil cap some day... It weeps oil just a bit.
As for installing the filter you might thing about mounting it under the fender up-side-down (in the front behind the bumper) so when you change the filter it won't drip all over you and make a huge mess like might does currently...
Here is my write up on it...
http://mopar.mopar1973man.com/personal/2002/frantz-filter/frantz-filter.htm
Posted Image
Posted Image
Link is broke again. Can you fix it?
  • 3 weeks later...
Question to you White... What is the filter cost to replace and how long do they last? Can you only get the filter from them only or is there other outlets? :shrug:
suppose to replace every 10,000 miles..and the spin on oil filter of your choice..i use the amsoil EaO O80...change the spin on filter once a year..and not sure if anyone else sells it or not. when i installed mine..the engineer i talked to said there is a 18 wheeler driver who installed two of them on his rig..not sure on his intervals for changing tho..he is running synthetic oil..and not sure how often the company(meaning FS2500) wants him to pull a sample..he has over 500,000 miles on that same oil..and they (sample lab folks) have told him to keep on a truckin!!
I am sure all these bypass kits are good. Its all about what you want to spend on them. Over 500 bones was to pricey for me when some of the cheaper ones have the same efficiency. But in the end its what you perfer :thumbup2:.But I have to admit I like my Frantz :woot:post-11448-138698188574_thumb.jpg
