p1693 mil fault in companion module
- Replies 7
- Views 17.3k
rlane547 3 posts
MnTom 1 post
Ilikeoldfords 1 post
joecool911 1 post
I'm having a problem again with torque converter lockup I think. Symptoms are different though. I can be driving 70 and for a split second its like it misses then goes back to normal. Sometimes at 30-40 trans shifts back and forth. When this started I got an apps code cleared it and did the apps reset but didn't accomplish anything. The alternator I had rebuilt the first time was putting out 0.1v ac but now it jumps from 0.12 to 0.34 so I know that's a problem. I borrowed a snap-on verus to do some diag and I get a p1693 fault in companion module. There are no other codes showing up and I can't clear this one. I've cleaned all grounds and connections. Any ideas?
