- Replies 8
- Views 7k
Frankstein 3 posts
Ilikeoldfords 2 posts
Mopar1973Man 1 post
joecool911 1 post
Hello, I've installed a Fass titanium 150gph and now my fuel pressure bouncing it goes from sometimes 14 to 20-24 and goes like 18-20 -21-17-15 bla bla bla ... change rapidly . I have an edge jwa with that electronic sensor. I dont think its the sensor it was good. The motor pump goes like on-off on-off .. . I drive the truck and I run fine even on WOT ... I take the suction line in the stock suction tube from the tank. run the 1/2 line to my stock fuel filter canister and put a 3/8 line from the canister to the vp44 to keep my banjo bolt and the pressure sensor at the VP44 . It's bad that fass don't give a fitting to fit a sensor with the kit! So if anyone can help me or already had this kind of problem of fuel pressure fluctuation will be greatly appreciated for tip and trick . Francis
