Help! Truck dead as a doorknob.
- Replies 10
- Views 2.5k
Mopar1973Man 3 posts
GSX455 3 posts
MnTom 1 post
mulcher812 1 post
I 've had some clutch interlock problems getting my truck started, I wiggle the switch on the clutch pedal shaft and the truck will start. Today I went to start it, and nothing. I wiggle the switch and then hop in to start it. No lights on dash, no odometer, Battery has plenty of juice, because I just drove it I checked the instrument panel fuse, and its fine.
I know my ECU harness had a few shorts, could that be the cause?
Also, while we are on the topic, can I use an automatic engine wiring harness on a 5 speed truck?
I would really like to drive the truck instead of work on it all the time.
Appreciate any help folks can offer.
Thanks
