draw straw 1
Anybody happens too have a good how to video on installing the draw straw. Ink finally going to poor it on tomorrowand I can find the instructions anywhere.
  • Replies 6
  • Views 4k
Would this help?
This is a different draw straw than what I have. I have the draw straw 1 from Vulcan. If I remember correctly I shouldn't have to drill the tank. Thanks tho.
I believe I got draw straw 5 the one that replaces in tank fuel pump, works great. The only thing I did different is ran a 1/2 line back to module with some jic fittings and didn't use clip on 3/8 return. That way return is not restricted and won't affect fuel pump pressure. I had to drill out 3/8 fitting from module and that's where I put my 1/2 " return. To bottom of fuel basket. I also threw away screen at bottom of module but kept red rubber valve in place, if I could find that little red valve I would add 2 more on bottom and not drill any holes on sides of module like they want you to.
