The sheet metal behind the kick panels that forms underneath the truck around body mounts.
Do they make this ? What's it called and how much of a deal to replace with those weld rivets for a body shop
Thx
  • Replies 7
  • Views 1.8k
Is your floor rotted?
Actually, Floriduhh only has a saly issue on the east coast. Brevars County is the most corrosive environment in the USA. 4 year old AC condensors (Home/business) have the fins 1/2 eaten away.
Ed
It was a PA truck. I've dealt with most if the rust once the front end is done next couple month or so ..... the only other part is this part ... i can't really get to it ... so my backup plan is to spray a rust inhibitor but I'd rather do it properly if not too $$
Basically if you look through the drain holes to the kick panels ... that metal looks like factory new ... but the backside of it ... that forms the sheet metal that goes under the cab near the body mounts .... that has rust ... not yet really bad but I'd like to deal with it
Thx problem is I'm not 100 percent sure which part it is and how much works involved to replace at a body shop ....
I'll snap a pic tomorrow too
; ipsSettings['maxImageDimensions'] = { width: 1600, height: 1600 }; const ipsJsFileMap = {"communitymap":{"front_markers":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_markers.js","front_showmap":"https:\/\/mopar1973man.com\/storage\/theme\/javascript_communitymap\/front_front_showmap.js"}};
