Fass electric heater in an Airdog?
- Replies 4
- Views 3.6k
Mopar1973Man 1 post
JAG1 1 post
diesel4life 1 post
TFaoro 1 post
Has anyone put one of the Fass electric heater kits in an Airdog FP-100? It looks like it will screw in next to the supply line from the tank above the water separator. With my Airdog exposed under the truck, even with anti-gel additive, it will gel up driving down the road.
It was -17 this morning and I made it about 1.5 miles to the store fine. I left it running and ran in for 3-4 minutes and when I got back in it started loping real bad and I noticed the fuel pressure was Zero. I shut it down, then limped it around to the back of the building out of the way so I could deal with it after it warmed up some. I finally got the fuel flowing about 2:00 PM and got it home.
The Fass electric heater can be run to a toggle switch inside the cab and turned on manually when needed. The heating element senses the temperature and will shut it off when necessary also. I'm hoping I can mount it in the hole next to the supply line from the tank and not affect the operation of the Airdog in any way.
The other option I was looking at was the WVO small filter heater wrap. It's much less money, but it pulls a lot of amps.
Please tell me the Fass heater will work....
