- Replies 5
- Views 2.1k
dorkweed 1 post
Wild and Free 1 post
IBMobile 1 post
hex0rz 1 post
Once again called out for another fire call. Been a busy winter time. Well this one was owner caused. Vehicle had a electrical issues and blew out a 40A fuse which the owner admits changing the fuse. Then he said the vehicle started and ran but rough. So he shut it down and hooked pu a battery charge and went in the house to warm up. Turned around to see fire rolling out from under the hood. His wife call 911 and myself and he was using snow to attempt to control the fire. Went I got there the fire was mostly out and quick blast of a dry-chem fire extinguisher kill most of it. Then I snip the battery cable and ran back fired up the pump and douse the remaining embers glowing.
Lesson for the day. If you blown a fuse you better find out why the fuse blew before stuffing another fuse in the panel.
