AIT sensor access?
I'm installing a mpg and high idle fooler. My hands are quite big and trying to determine the easest way to make the connection to the ait. Take off the bracket for the dip stick and remove fuel filter? Or find an Aisian woman to help? Lol.
Edited by joecool911
  • Replies 11
  • Views 2.8k
Are you sure you got the right sensor?  Been a while since I messed in that area of a 24 valve, maybe it's different then a 12 valve.
You mean you guys don't just crawl up over the radiator and sit in there.
I guess being 130 lbs has its benefits...now if I could just see over the steering wheel.
Chris
I put a 33X12.50" tire mounted on a rim with plywood on it right near the drivers tire & reach in while standing on it.
Ed
Back in the shadows...
Man, that sucker is clean. What products do you use?
I made my own IAT fooler (only) & mounted a toggle in the knee panel.  Works great!  But man, it was a pain to reach the sensor to plug in the extension harness.  Like my boatyard days, I climbed up on top of the engine.  Laid cardboard over sharp corners & laid on it to reach.  There was blood spilt getting it done.
Or...
cd6771ce-868a-4875-9d47-44463c746c99_400
3,000 PSI power washer.
Are you running that stuff through the suction line of the power washer?
