- Replies 8
- Views 2k
Dieselfuture 3 posts
bjytech 2 posts
Cowboy 2 posts
TFaoro 1 post
On a 4x4 I only see two adjustments for alignment, one next to gear box ( gets steering wheel straight) and the other by passenger side ( does tow in out ), if you don't count control arm adjustment. Am I missing anything? I measured tire tread front and back on level ground and my toe was in the front (both tires pointing in) so I adjusted it a bit and now it measures almost exact front to back before I had just over 1/4" longer in back. Anyone know where tow needs to be 0 or +- . Also why would truck pull right even in left lane if only one adjustment for tow, so no mater what, both tires should split difference equal and steering wheel would be off to left or right. After I got tow adjusted better to center it seemed to help from pulling right but still does it.
