- Replies 16
- Views 4.4k
NBWW 7 posts
Mopar1973Man 6 posts
dorkweed 1 post
AH64ID 1 post
I posted the below info in the 2-stroke thread, but this is really the place it should be kicked around. Any opinions are appreciated."I have run maybe 10 fills with 100:1 and something is not right. There is a loss of power and the turbo seems a little louder when accelerating. It didn't happen until a 1000 mile trip heavily loaded.Still not sure what is to blame though. I have an apparent issue with the grid heater or something because the voltmeter will cycle, and the tach goes to near zero if under about 1400 RPM (all the time).This weekend I plan on reading the codes, and checking alternator output at idle and higher RPMI don't want to hijack this thread...will post in the appropriate place."Also will someone verify the ignition sequence for reading codes? Specifically, how many time on/off.
