P0243 Code - No +12V to wastegate solenoid
So lets start with the code I know its not list here. The P0243 code is a wastegate solenoid issue. Either there is no +12V power or no control from the ECM on the ground side. Now I can say that this wiring diagram is not very helpful at all. The wire colors are wrong here too. The plug at the solenoid is Dark Blue (ground to ECM) then there is pink/yellow. Then tracing back from the solenoid I do have continuity from the pink/yellow to the C130 connector. At this point the wire swaps to red/orange color heading to the TIPM. Now that red/orange wire now there is two connectors in the TIPM that have this red/orange colored wire going to the module. One is constant hot +12V the other one is dead even key on. A friend informed me it might be powered with tach signal (engine running). I've thought of cutting in a new key hot power line to the c130 connector and going form there. I don't want to start chopping up wiring to make this work. The other problem is there is no continuity from the c130 to either red/orange in the TIPM. Now I'm stumped. Little info or help would be nice... ADDON: I finished my oil change and then fired up and checked the orange/yellow wire at the TIPM and there is no power present. Fuse is good. Power across the fuse as well. Even with the solenoid removed from the turbo and unplugged there is no code for the solenoid being missing. I figured it would pop the code fairly instantly. According to the 2006 Dodge FSM • When Monitored: When the ignition is on. • Set Condition: The ECM detects an open or short circuit in the Wastegate solenoid circuit.
Squirrels Got Me Good
@JAG1Sorry to say I can't use a stock air box too restrictive for Beast. I'm sure not going to dust a good engine with washable filters so BHAF is the solution. Filter in a wire mesh cage.
Loud rotational front end sqeal
IR Thermometer could be had at Harbor Freight for cheap. https://www.harborfreight.com/121-infrared-laser-thermometer-63985.html?_br_psugg_q=infrared+thermometer It's not like we are measuring temperature for exact. But these cheap temp guns do work and will temp roughly tell you how hot or cold something is.
Throttle linkage stuck at idle - cannot accelerate
Might pull the sensor off the back and use some silicone spray or WD-40 to displace the water.
Happy New Year
Here we are January 01, 2022 Starting the new year.
2001 RAM 2500 Heat Exchanger
I'm more of a manual guy. But... I'd say upgrade the cooler only if your trans temp was up to 200°F too often. Then I would up grade. Seriously my Dynamic 46RE built 1/2 ton Dodge ran seriously cool most times even hauling trailer. Proper built trans will run cooler. Also proper final ratio. Even that truck was running 215/85 R16. So that made it 3.6x:1 or so.
No Start
Blue Chips special X is too advanced. That's your hard start or possibly the key is crushed and timing is advanced. I've seen both cases causing hard start. Fuel pressure to high could cause hard starting. Fuel pressure should be 7 to 12 PSI. Should not be any higher during cranking. Try unplugging the FASS and see if it starts easy. Excessive pop pressure on injectors greater than 330 bar. Make it tough to start cold. For easy starts low fuel pressure and retarded timing is way easier to start.
Even AFe with the airbox is a mouse condo. BHAF is pretty good choice and I've not seen and had any problems.
Leave the hood open. Most mice and rats won't hang around typically.
2004 3500 Manual Trans Conversion (APPS)
- Stuck Idle problem
Just enough to lube everything up. If you rev the engine it might squirt a bit more or fling it off the rockers.- Stuck Idle problem
+50 HP are custom made. So yes they are pop tested and flow matched. You'll also find the +50 Hp are typically a bit cheaper the RV275.- Winter weather - What do you see where your at?
...VERY COLD TEMPERATURES EXPECTED OVER THE HOLIDAY WEEKEND... ESPECIALLY SATURDAY MORNING... Skies will clear and temperatures will become very cold late Friday night into Saturday morning. Low temperatures in the valleys are expected to be from around 5 above zero to 10 below zero, with mountains generally in the 5 below zero to 20 below zero range. Sunday will be not be as cold, but most locations will be in the 5 above to 5 below zero range in the morning. Fortunately, most winds will stay below 10 mph during the coldest periods. However, the Camas Prairie will have dangerous wind chills down to 35 below zero Saturday morning, with a significant risk of frostbite. Other areas will have lighter winds and will not be quite so cold, but even light winds can lead to frostbite at those temperatures.- Merry Christmas!
Ummm... Well Beast is only 438k miles and Thor is only 238k miles. Must be thinking @dripley being he's been to the moon and back.- Credit Card Smoking
I prefer the A-pillar with ISSPro EV2 gauges because the EV2 are USB programmable and you can set the warning light to any values you want. Adjust needle movement being more accurate or more averaged and smooth. Quadzilla display I only look at it for tuning purposes so typically I don't have the display running. But the ISSPro gauge warning light make it super nice because you can tell what is wrong but level on the a-pillar. I though of adding a tweak and getting the relay option for the gauges and I could tap the cluster possibly and hook them in so when the warning lights popped it would set the light and chime the central timer. Now that would be super cool.- Merry Christmas!
How do you know? Hmmm... Been watching?- Winter weather - What do you see where your at?
22*F out this morning and snowing really fine powder. Then getting ready at about 10am to head to Lucile to work.- Stuck Idle problem
I'm running DAP's 150 HP (7 x 0.010) VCO Injectors popped to 320 bar. With these injectors, Quadzilla Adrenaline with my Economy Tune I broke my old high mark and topped out at 28.04 MPG. Just this last summer.- Credit Card Smoking
Do yourself the favor and opt for +50 HP injectors over the Bosch RV275's. At least you can get a custom built injector set that is flow matched and within a small margin for tolerance. Just really sucks to dump in more money for Bosch stock injectors that are 6 random injectors. Like another member here just got a bad batch of RV275's that popped at 220 to 260 bar. I would also suggest the Quadzilla over the Edge EZ. Way better control of timing and fuel parameters over the EZ that is just a dumb box tuner that can't really be adjusted to meet your needs of good economy and/or performance. Hua... Well I've been doing more mobile work lately running all over the local area handling broke down vehicles or trucks that didn't start. I'd love to hang that up and do more the web work than travel work being its barely 16*F right now and going down to near zero tonight. Sucks to start your morning fighting the ice and cold. Ugh...- Better fuel mileage with a Dodge/Cummins truck
All I can say is give DAP a call after the holidays and see with the gang there has to say.- Better fuel mileage with a Dodge/Cummins truck
The other way is to get your hands on a Smarty S-03 programmer and then flash one tune to the truck and then return to stock and your done. The high idle software is left on as a freeble. https://www.dieselautopower.com/smarty-s-03-rental-sr-s03a As from DAP's site...- PS Pump Replacement
I'm curious too. Scratchging my head the only other vendor I use but don't exactly support is RockAuto... (Guessin')- Stuck Idle problem
Yup I kind of figured. The high idle and the engine load of ZERO. Again the pop pressure was so low it could not cut enough to idle slow enough. Like I said go to someone like @dieselautopower for injectors and then you can specify anything you wish. Size, nozzle type (VCO vs. SAC), pop pressure changes, etc. But all in all the injectors are built in house and pop tested and flow match before leaving.- Stuck Idle problem
Something is wrong even here being the engine load is zero. Even all the trucks I've worked on always showed at least 7% to 15% depending on size and pop pressure. Even my 2002 it idles at 13% still to this day. Now you mention Bosch RV275 injectors these are some that I don't suggest because they are 6 random injectors pulled and boxed up. There is no flow matching or pop testing to bring them into small percentage of margin. I typically would rather suggest 50 HP custom made at least you know all the injectors are tested, flow match and within small percentage of error..- Stuck Idle problem
Ok... So the APPS is replaced and now lets move on to other topics. So I guess you have factory stock injectors yet? How many miles on the injectors? Another way to look at this problem is hook up a live data tool with the truck warmed up complete and monitor the engine load if its 3% or lower to ZERO then your injectors are wore out and the ECM is attempting to cut fuel as deep as it can but since the injectors are popping too early and there is no longer any more control the ECM can try to pull the RPM's down. Second way to test this is to remove all six injectors and have the injectors pop tested typically about $15 a injector about $90 to test all six injectors. Solution to this is replacing all six injectors. Like I said you can verify with a live data tool and check the engine load at idle warmed up. Pop pressures in Bar (PSI) 280 (4,061) and lower - Typically the idle is rising and the Engine load is zero. 293 (4,249) - Bottom end of allowed by Dodge FSM 300 (4,351) - Some performance injectors are popped this low to aid to flow. 305 (4,423) - Fairly common pop pressure used by performance injectors. 310 (4,500) - Stock Injector pressure 320 (4,641) - Personally what I run on my truck to aid in fine mist spray and MPG. 327 (4,742) - High end of Dodge FSM allowed pop pressure 330 (4,786) and higher - Possible hard starting in the winter time. - Stuck Idle problem
