which tuner/programer??
I've played with several Edge Juice and Edge Comp systems. All I can say is that they work with stock fuel systems fine. If your wanting to upgrade to bigger injectors past +50 HP it becomes a smoke bomb very had to control the smoke. When I upgraded to +50HP injectors I had to drive with a serious light foot to prevent smoking. This was the end of my Edge Comp days ands was replaced with Quadzilla and then the bigger injectors started getting used. Quadzilla is very clean even all the way up at 150 HP injectors. I've ran +50 HP, +75 HP +150 HP injectors on thew Quadzilla. No problems and easy to tune it clean and powerful. Like currently I know the max EDge Comp will give is close to 21* but I need 24* for cruise timing art 2K RPMs. This makes the bast MPG for my setup currently. This is where the Edge Product come short is the fact you can't adjust timing at all. The fuel map need to altered to put the fuel in the need position of the map but can't. Hence why Quadzilla can produce clean power and Edge products are very smokey and dirty tuners for large injectors.
Ground Reference VP44,ECM,PCM,PDC plus TC lock/unlock
Not required for stock setups. I'm completed the W-T ground wire mod. I'm still very stable at 11 to 13mv AC. The extra cable isn't going to make a difference if you don't run the extra double to the starter. W-T did a lot of extras because of noise issues on ham radio. Plus his ham radio drew quite a bit of current. This is why the double was used for his purpose. For us that DO NOT have a ham radio and just driving a truck you can still get away with the stock cables which I'm still running my stock battery cables. Now if you have a winch on the front bumper now I would do the dual cables battery to battery because of the draw to the winch.
Truck started stuttering again
I'm going to say more electronic way it comes and goes randomly. The only thing I would figure is fuel related is huge air bubbles.
Not required... just optional. Even my truck without that still 11 to 13mV AC.
Yet another injector and turbo question
Mopar1973Man replied to Rather Be Wheeling's topic in 2nd Generation Dodge Reliability / PerformanceI'm close with 7 x 0.010 @ 320 bar and HX35/40 (60/60/12) turbo and bit of Quadzilla tuning. Easy 20 to 21 MPG.
Morimoto HIDs Headlights in a 2nd Generation Dodge
Just in the two years of ownership on my Morimotos HIDs I drove hours with my lights on driving back and forth to Ontario. Im close to 3,000 hours burn time roughly figuring. Typically run them when traveling or in the city. Then include the many times I've left my lights on too. Come out later to find them on. Thank Gawd the LEDs and HIDs don't draw much.
Rooftop ac issue
Might be on a relay socket. I've seen a few this way. Then I've seen some that are just fully electronic control.
2001 ecu
Rare to happen any more that was an early Revision number. There hasn't been failures like that since early 2000's. Just like torn diaphragm that can't happen because new pumps don't have that rubber but steel disk now.
Rooftop ac issue
Might look up in the air intake there typically is the electronic controls for the A/C to thermostat controls.
I bit the bullet...
Deletes like that are no longer needed.
Moving to almost the great white north.
Nice...
Did I fix everything?
Never had any problems with my vents. Every 30k miles change the fluid then with the cover off and draining just use compressed air and blow it out. Not even when I was towing back from Mohave Valley, AZ. Never used synthetics, and just standard old 80w-90 GL-5. 415k miles and counting.
Quadzilla adrenaline custom tuneing can bus fueling
Mopar1973Man replied to Project_blackgold24v's topic in 2nd Generation Dodge Reliability / PerformanceOh my this is going be impossible to clean up. Tires being 35 inch tires your final ratio is too low at 3.21:1. This is going to require lots of fuel to get turning. Optimal you would need 4.10 gear to fix this. Like myself I swapped out to 30" tires this raise the final ratio to 3.69:1, more torque to the ground, extremely low EGT's, no smoke at all. 650*F at 80 MPH at 2,450 RPM in 5th gear. What size injectors? (Found it ( 7x 0.012) injectors in the first post) 3,000 pop is too low. Stock starts at 4,500 PSI or 310 bar. I'm even using 320 bar (4,641 PSI). Turbo in my opinion is too big. Spools too late. Hence your smoke, you can't spool that big turbo quick enough quick enough. Optimally 62/68/12 will support 150 HP injectors up to 200 HP injectors. I'm even running HX35/40 hybrid (60/60/12) with 150 HP (7 x 0.010) @ 320 bar which spools extremely fast and giving me just at 47 to 49 PSI of boost. Still think the turbo is too big.
Tach wont read past 2k RPM
- 2001 ecu
My last injection pump died on a trip to Riggins, ID as well I went to town to visit with a friend there. I got to town pick him up and the engine started knocking barely had any power. It threw the P0216 code and lit the CEL. Truck would still run and drive but very weak on power barely 25 MPH till I got home. The timing was stuck in full advance! My OEM pump died at 50k miles with P0216 code and white smoke and low power. Pumps that die without warning typically the PSG unit burned up and now after talking to people W-T ground mod is now closing that door some what. Like my truck the fuel temp and IAT temp are always the same. Typically below 130*F on the worse case heat. PSG typically do not burn up with good fuel pressure to keep them cool. Another tidbit there is no heat soak rise on my truck I can run hard for hundred of miles and the fuel temp always falls when shut down not rise.- Engine surging... at a loss here
Do keep in mind Blue Chip does sell pumps with used PSG units. DAP on the other hand sells VP44 with only NEW PSG units. Typically lower price than Blue Chip.- Quadzilla adrenaline custom tuneing can bus fueling
Mopar1973Man replied to Project_blackgold24v's topic in 2nd Generation Dodge Reliability / PerformanceNeed this information to help you...- Weird fueling issue
Just keep in mind after 100k to 150k miles to just change out the injectors. The o-rings are typically cooked and getting weak. Then the injectors seen all that heat for all those miles and the heat cooling cycle on the springs. Pintle moving up and down in just diesel fuel for lube.- Sound like a boost leak ?
I can give this much... I created a massive boost leak on my truck to test the boost leak theory. I removed one intake manifold bolt, and remove the wastegate hose from the turbo. Took it out for a drive typically I can reach 47 PSI of boost. With this massive leak I still reached 43 PSI of boost, EGT's where unaffected by the leak. The air whistling out of the two spots was very loud and couldn't be miss. I drove for several miles like this with no ill effect. 7 x 0.010 Injectors HX35/40 Hybrid turbo (60/60/12) Quadzilla on KILL (Level 7) Even with a massive leak you can hear it will not change the boost or EGT's very much.- Did I fix everything?
I've never had that happen... I've had the reverse of that happen and finding the front diff mixed with water.- Surging I think
Still doesn't fix the excessive long ground issue. This ground lead is TOO LONG! Still running right pass the alternator charge line.- Quadzilla adrenaline custom tuneing can bus fueling
Mopar1973Man replied to Project_blackgold24v's topic in 2nd Generation Dodge Reliability / PerformanceStart at about 80% and work your way up. Also I would have to know several other factors. Tires size Axle ratio Transmission Injector pop pressure Turbo- Built 47re for towing
I had @Dynamic build my 46RE in my 1996 Dodge 1500 to be more like a 47RE. He milled a 0.1 of a inch off the overdrive and direct clutch added an extra clutch disc and added cooling jets to the body of the case to keep the clutches cooled and lubed properly. The custom modified valve body that shifts firm. This is one tough little transmission and it shift like one too.- I bit the bullet...
Should of talked to me first there is a much better way.- No Change in AC Readings (Post Ground Wire Mod)
No.. Please don't. That creates a masked problems. Best to leave all filters off the system fix the source. Don't mask with filters. - 2001 ecu
