Hi everyone
Sorry for the lag time It has been a bit crazy for me being I've been dealing with cancer. Welcome to the site!
ECM failure
Should of kept it. You just ditched a good fuel heater and a secondary filter.
Is my grid heater dying?
That sucks. But the truth is just because you can hit the old adjustment doesn't mean it will be the same setting as the old bushings or front-end parts. I tried doing the same for tierod replacement and adjusted to the same length of threads measured but because of small differences, it ate the front tires up in a mere 250-mile trip.
Track Bar
Same here I just get the economy line and no issues just expect in 100k to 150k miles it will be getting lose.
1999 Dodge Grand Caravan - Minnie - Electrical weirdness
Minnie has been down for a few weeks with electrical issues. The funny part is the solution was straightforward. Remember start easy start at the battery terminals. Sadly I started ripping the dash apart thinking the ground issue was in the cab being the fuel gauge would drop to empty and chime there was no fuel left there was over a 1/4 tank. I've got another I've gotta check on power door locks but they just quit. Maybe a fuse? Minnie is back to running with a bit of effort.
2001.5 I think I need a new ECM where are we getting those nowadays
Nope. Quadzilla is not to blame being mine is close to 10 years old. My factory ECM has 495k miles never failed yet. AC noise issues kill the ECM we have the W-T ground wire mod which solves the failure.
Track Bar
494k miles still using the factory track bar. Never used any of these products. Just remember no oversized tires. The lifespan averages about 150k miles per track bar for a life span.
Archoil Friction Modifier
Out here lubricity is low. Bosch VP44 require 460 HFRR or lower. Most all fuel is roughly 520 HFRR. Might read about the fuel additives in the article database.
This is why I created the vendor listing then there is another article that we hunted for good ECM/PCM rebuilders. You are welcome!
https://mopar1973man.com/vendor.htm/vendor/auto-computer-specialist-r5/?do=getNewComment&d=7&id=5
Can you check your error codes using the key trick by chance? I want to know if there is any codes like P0606.
Magnum Thermostat housing bolts
Hmmm... I'm not sure for a V8 5.9L... I could offer the parts book for the truck and see if you can locate a part number to search from. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/part-number-lookup-tool-2nd-gen-24v/2nd-gen-1998-dodge-ram-part-number-lookup-r459/?do=getNewComment&d=4&id=459
Obd link lx
Remember I'm 143% of efficiency on Beast in a older post of mine I posted the brake specific fuel consumption. I'll dig on this a bit later. I'm currently rebuilding my local server here at home.
Obd link lx
Sorry for the lag time... This can be done. Like my setup with my injectors the flow rate is 143% of normal for Diesel Auto Power 7 x 0.10 popped at 320 bar. This has to the factored in. The horsepower is going to my flywheel horsepower but calculated based on the torque calculation.
ECM or something else?
Another way is the lift pump pressure constant or hang low and jump high? If the low and high problem that is a air bubble being pushed up the line to the injection pump. Currently fighting the same issue on my 2006 Cummins with long crank times but 3rd Gen has a clue with the grid heater light coming on and chiming either 5 or 10 times showing fuel rail issues. 2nd Gen's just any long cranking is loss of prime on the fuel system.
Help with Quadzilla 3 cylinder/6 cylinder box
No. Because in fooler mode the resistance is fixed to a particular value its like you have internal resistance differences or there is a malfunction some how. OFF - All normal values of IAT and ECT sensors. No fooling done. MPG - IAT sensor is disconnected and forced a value of 143℉. 6 CYL - IAT sensor is disconnected and forced a value of 26℉ and the ECT sensor is disconnected and forced a value 123℉ 3 CYL - IAT sensor is disconnected and forced a value of 13℉. If these values cannot be obtained then high idle system will not work properly. The key notes the IAT is the trigger to start the high idle and the ECT can prolong the high idle only if the mode holds it below shut off. Hence why the 6 CYL can be used for jump starting because the coolant never reaches the cutoff point. If you wish, give me a call at (208) 315-1470 - 9am to 5pm MST. I'll go over all this in greater detail.
So, with your loss of prime, you will have to look at possibly replacing the injector crossover tube. The other thing is did you torque the injectors first or the crossover tubes first? As for the tach. You will need to flash the ECM and PCM with the correct software to match and VIN numbers have to match too. There is dozens of versions of software which could be your problem being no VIN numbers match between the PCM and ECM. Remember the PCM is the primary controller so it can disable communication with the ECM because of software errors.
ECM failure
I reused that grey connector from the ECM ground as my additional ground to the battery on the driver side. Looks pretty factory except for the ring terminal on the driver-side battery.
2006 Dodge Ram 3500 - Thor Project
I've got a sheet of metal here I can cut a full width chunk and tack weld the piece in place. Then straighten all the remaining edges and weld them down to the sheet metal. Now like get a gallon of Hurculiner and cover the host of sin on the bed bottom.
I was just talking to Mark about the bed floor and my idea of fixing that quick.
ECM failure
Additionally, I would take the truck out and drive it a few miles to put a good charge on the batteries after starting cold. This will stabilize the test and prevent the grid heaters from stealing power and fouling the measurement. Just after your drive leave the engine run and test now. This should be a stable test then.
ECM failure
P0606 is a ECM death code. Try resetting but I'm pretty sure it will return. @Auto Computer Specialist should be able to fix it up for you.
Made the trip out to meet my guy on the bed trade I'm doing. I'm trading the super heavy winch bumper and the steel flatbed with toolboxes. Here is the bed I'll get. Yeah it's rough but workable. Now to get my injector back in Thor so i can roll it out of the shop.
Still something wrong. Wrong values for 3 cyl and 6 cyl is half right with 123°F coolant. @Quadzilla Power
Go back and check. 6 cyl should show 26°F IAT and 123°F ECT 3 cyl should show 13°F IAT and normal coolant display. Operation Turn switch to setting you wish. Start the engine. Then after high idle starts in 2 to 3 minutes you may turn it off again and high idle will continue till 170°F. NOTE: To slow of switch change could trigger only 3 cyl mode. If so turn the engine off and wait 10 seconds and restart to clear the previous 3 cylinder mode.
