From the album: Beast - 2002 Dodge Ram 2500
Titanium
My adventure of having a second run at bladder cancer and going back and forth to chemo treatments and surgeries. "Titanium" the character, kept me going and helped me with depression and stress of the idea I might not make it. I've made several new friends and found a new way to enjoy life as I continue to dress up and do my Titanium makeup. I'm always taking my adventure out into the public and share my artwork with everyone!
Busy Man - Titanium
Beast got his new VP44 injection pump. Been a long while since I've done long work like this, wow! I can feel it all through my shoulders and arms from hanging upside down over the tappet cover and injection pump. Few flaws I did on that job. I got sidetracked by people coming and going, and then forgot to tighten the 1,2,4 injection lines at the pump, and couldn't figure out the diesel fuel smell. D'Uh! 🫣 Tighten all that up, and Beast came to life. To test Beast out, I packed up the next day and went to the local C&M Lumber. No wire taps yet, but I will soon be reinstalling my BD Stealth Plate. I ran up and got 20 feet of 6 AWG wire and a few bags of copper ring terminals. Yeah, work time in the RV. The main power lead into the house is bad and dropping voltage. Since I already have the 6 AWG from the battery to the inverter I opted for making that my main lead in the house, which is double is size from the mere 14 AWG main line coming from the factory wiring. Rebuilt the entire power cabinet and re-laid out everything. Now the power issues of the past RV trip are no longer an issue for our future trip to Boise for medical. Wife still has a shoulder issue that needs to be dealt with. All this was repairs from the failed trip to Boise, where we made it down to Boise, but the VP44 injection pump failed out with a P1689 code. While travelling back. Then, even the next time I wanted to move Beast to repair. VP44 threw the P1689 code again.
Electrical gremlin or valve body?
I've got some of the older diodes with the post in the back of the alternator. Most alternator shops sell the diode packs for ND alternators. Bosch on the other hand, is soldered diodes so those are a bit different.
Using Google Gemini AI on Ubuntu 24.04
Before in the old cabinet. Too hot too! Here is some eye candy of the personal server here at the house that will become the sandbox for testing software out and even building software to do other tasks for the network and website. The whole wooden cabinet is gone. Now the server is condensed down to a mere 32-inch-high box with all the equipment stored under lock and key. The network is being rebuilt. Now the new server cabinet. I'll get a better photo here soon. VLANs Workstations IoT Camera Trunk (All) IoT (Internet of Things), I'm going to place all 4 Roku's, and then there is the Verizon extender, also stuff in the VLAN. This way, there is no way for Roku hackers to get into my network becomes a dead end. Other devices will be added to this like the Acurite weather head will be added to this Iot group. Cameras are moved into a special VLAN too so they are totally seperated from the rest of the network. Workstations are given a bit more permission to roam the network that any WiFi devices but there will be a few devices that will be given above normal permissions.
Steering gearbox replacement
Still got my blue top steering box and had to adjust it once so far to take up gear slack, but still working awesome. If you are not doing oversized tires, you can opt for the quick ratio box.
Website Issue - Uploading photos
This I will consider solved at this time. I've not had any problems handling photos at all and all uploads work fine now.
As I've been working on the website I've been doing a lot of tuning work to make the software faster. I've got that done with the help of AI. Google's Gemini AI has been a invaluable tool in getting the server fixed up and working really good. I've dropped all the blocking time of the CSSscripts and the java scripts. Now it test out at a pure 0ms blocking time. Most pages score in the 90s percentitle.
New to Auto Transmissions
Well he was a rebuilder for the site years ago. I was hoping but I guess not.
Even though the fallout but i would say try Dynamic Transmissions out of Washington. He actually is really good builder. Even custom valve body set ups.
Rear Backing Plate Shoe Pivot Pin
Grab a part number book and then look up the part number of the item your looking for and then do a search for that part number and maybe the part description. https://mopar1973man.com/cummins/articles.html/12-valve-2nd-generation/part-number-lookup-tool-2nd-gen-12v/ Might help to have your profile filled out so we can see the make and year. (Tip)
Happy Birthday to Tweety Bird
May 26th is her birthday. Strange that the two of us have the 26th for birthdays. Then, strangely enough, our wedding day is the same as when we met—the 25th of June. Yes, we are still going to get married in public. @Tweety Bird asked for green today and not the dark green.
cleaning axels for rebuild (axel tube)
Inside too? That's tells me seal issue or pure abuse to have debris inside the tubes. Outside no problem. Just pressure washer the diff housing. You could pull the guts a pressure wash the inside too. Then air dry. Then dust with WD40 to retard rusting. Then paint the outside and load new guts (bearings and seals).
Remember the notation. 47RE 4 gears forward 7 on a 0 to 9 torque scale R ear wheel drive E lectronic Shift 4th Gear 48RE is the same mostly but the torque limit is higher. Plugs and connectors are most likely the hang up.
power locks
This will help on keyless entry on power door locks.
Hmmm... I've never had an issue like that where there is crud in the axle tubes.
VP44 Injection pump - 505,363 Miles - May 23, 2026
Our last trip down to Boise ID we were going to dry camp with the RV as @Tweety Bird had medical appointments. While down in Boise / Eagle area Beast just died and jumped back to life.I called it and was the VP44. Fast forward we get home and park Beast beside the RV. Fast forward again yesterday i went to start Beast and move.Nope no start. Bummed I was going to have to work out in the yard. This morning I figure to try starting Beast again. Long crank but it started. Quickly move over the garage door so I could start the replacement. Managed to just get the pump out. Sad part is im not as strong as I once was and everything seems so very over tightened. Really its not im just that weak.
From the album: Thor - 2006 Dodge Ram 3500
Thor - 2006 Dodge Ram 35005.9L Cummins Turbo Diesel, 6 speed (G56), 4WD, SRW, 253k miles AirDog 150 GPH, BHAF, +50 HP Injectors, Valair dual disc clutch, ISSPro EV2 gauges (boost, pyrometer)
