Truckaddict
  1. Alligatorperformance (dot) com has II heads stock-perfomance. Ive bought a couple things from them and been happy.
  2. When i did my CAI i figured i would give it a shot. I like it...sometimes its a little much but road barriers and over passes are my best friend. Rolling my windows down at - degrees
  3. OHHH that figures i just got my adrenaline in december :banghead:
  4. ive always had the flywheel turned just to be safe. Last one i did the local shop charged 25 bucks and had it done in 2 hours
  5. Maybe a set of u joints in the axle while your in that deep? I had to do wheel bearings, ball joints and u joints all in one swing....and when you put the new ball joints in really make sure you clock it correctly so the grease fitting clears the u joint (i know its common sence but i learned the hard way trying to get it done fast) good luck!!
  6. Just a heads up on the toyo's make sure you rotate a lot. The guy who had my truck before me didnt and they got chewed up in about 20,000!! :banghead:
  7. Ya know i was just thinking the same thing! I just put my quad and 3 piece on two weekends ago and at level 5 (cant go higher with out slipping the clutch) i slam right to 40....not sure why and i was kinda worried so i set my defuel at 35 to be safe
  8. HEY guys nice to be apart of the group.. lil history... Loved trucks as long as i can remember, so of course thats means ive been fixing them for as long as i can remember :lmao:Ive wanted a diesel since i was around 18 and 8 years later i got my first cummins!!! So hope to be hearing a lot from you guys!
