Everything posted by kbf98520
Beast is falling apart!
Sounds like regular maintenance for one of these pickups. Lol . I need to also replace the dash in my pickup right after I finish the lift pump fiasco next month when I get back home
Fuel psi problems
Yes return from pump
Fuel psi problems
When I ran it today I had 23psi at idle. That’s way more pressure than I had when the pump was new so I disconnected the return to tank and ran it into a bucket. 15 -16 psi at idle. That tells me there is a restriction in the return circuit. Going to drop the tank and figure out what is going on on
Fuel psi problems
Plugged pump return . Flow into bucket 16psi ,into tank 23 psi. I get to drop the tank again . I’m so excited…….🙄
Fuel psi problems
Got back on this issue today. I have replaced OFV valve. Im not confident this has fixed anything. I test drove the pickup and psi’s are 19 WOT to 23 at idle. This is not at all consistent with psi’s prior to this issue. Prior to this issue I had 17-19 consistently. I am going to continue driving this thing locally fully anticipating it to fail again….. ?
W-T mod question
Have you had the breaker trip? It must be a pretty rare event, being the fusible link in my PDC has never been replaced
W-T mod question
Thank you. I just waiting for a fuse housing to be delivered and I will be done with this mod. I wasn’t able to find a 140 amp setup so I went with 150. Will this be a problem?
W-T mod question
I’m in the middle of this project, so if anyone has an answer or feedback I’d really appreciate it. It seems like a pretty valid question. Sorry if this has been covered before.
W-T mod question
I’m pretty sure this has been covered, but I can’t find it. So the way I understand this the alternator feed into the PDC is eliminated. There is a 140 amp fusible link between the two hot leads going into the PDC what is the purpose of this? Do I need to bring that second lead going into the PDC to the driver side battery or is this not needed?
Fuel psi problems
Thank you
WT mod
Yes, thank you
WT mod
Great! Thank you very much.Could you also share Moparmans write up please?
Fuel psi problems
intermittent fuel supply blockage, especially suction side of lift pump large amount of air in fuel system (not likely) intermittent power to lift pump faulty lift pump (pressure regulator issue) What would cause intermittent power to lift pump?
WT mod
Can someone please direct me to the write up on this or share a link. I’ve been all over looking for it.
Fuel psi problems
Well instead of chasing parts around to test OFV like another air regulator I just ordered one from Genos . While I’m in the wrenching mode I’ll use this shipping time for other projects I’ve been putting off. WT mod, battery cables, headlights, and door assembly. I’ll let you know when I get the OFV replaced. I think the only other thing it could be is an intermittent suction clog.
Fuel psi problems
- Fuel psi problems
I just verified flow. Filled 1/2 a five gallon bucket in less than a minute with first the pressure side then the return side.- Fuel psi problems
Actually psi is about 19 initially then jumps to 22.5- Fuel psi problems
Ok, I’m home and back on this pickup. This morning I ran the pump with pressure feed to engine plugged to test FASS return circuit repeatedly and got a steady 17-19 psi . I’ve now done every test recommended by FASS they are again suggesting OFV failure. They explained it as dumping pressure prematurely. I get good continuous suction and pressure with every form of bucket test I’ve done. I have not run the engine out of a bucket. I don’t see why that is needed. Kevin- Dodge Hydrobooster replacement - Proper way!
Great write up thanks. Ok, help me with this please . Where does it get the power assist from? Years ago I had to change out a vacuum booster on a gas pickup I had, but this being a hydro booster I’m assuming from the PS pump?- Fuel psi problems
100 GPH. Spellcheck got me- Fuel psi problems
It seemed like I might have had another bad relay , so I jumped it, pressures were all over the place, from 20 to 12psi varying rpm’s. I did another bucket test had a constant 15-16 psi for an hour. Hooked the pump back to the truck, keyed it on psi went to 20 briefly while the truck warmed up then psi was all over the place 20 to 12…. FASS is leaning heavily towards OFV in VP 44. IDK- Fuel psi problems
That’s right, same symptoms after 100 miles or so and it seems I’m starting to get the not answer the phone/ not call back run around game on the lifetime warranty from FASS as it now seems to be an electrical issue in pump, best I can tell. Just ordered one. Unfortunately, I have to go back to work and I won’t be able to get back on this with the code reader until February.- Fuel psi problems
Can you recommend one? I’ve been meaning to get a quadzilla . Does that have code reading? Or maybe just a basic code reader for now?- Fuel psi problems
I had a scan gauge on a power stroke. It worked well. Can you suggest one for this pickup. - Fuel psi problems
