kbf98520
Monthly Subscription
Everything posted by kbf98520
  1. So I have a FASS titanium series waiting at the house for me to get home and do the install. What’s the consensus on suction? Draw straw or sump?
  2. Wish I could help you. I need to do this to mine also. I did not know that this could be activated by a dealer. My plan at this time was to do it with a Quadzilla w/Iquad tuner that is high on the to do list. How much did your local dealer want? I hate to think what mine would want at 165.00 an hour labor
  3. Pardon my ignorance, but where do I find the article from W-T
  4. I’m real leary of tools from Amazon, but I’m not a fan of the prices of Jim’s either. Decent quality?
  5. I do. The Bagger is 05 TC88 bored and stroked out to 117” . Fun
  6. Thank you for what you do
  7. kbf98520 commented on Mopar1973Man's Cummins article in Cab Interior
    As always great information, very detailed
  8. Were you able to get the truck up high enough to sit or were y’all on your backs?. I’m sure they’re heavy. That one we did in that square body yrs ago was real heavy
  9. Did you have your pick up on a lift . Did you have a good transmission jack? I helped a buddy do a clutch years ago on a square body Chevrolet. ( my only real transmission experience) What a s@#$show that was😂. Laying in the dirt underneath the truck manually bench pressing the tranny into the pilot bearing
  10. Thank you. I’ll look for your thread
  11. I value your opinion and I appreciate your time. Hope you don’t mind if I continue to pick your mind for a bit. Had you done anything with 5th gear before it grenaded? How many miles on the tranny? Is the countershaft bearing another weak spot on these transmissions? Have you looked at a 5600 conversion? Did you rebuild your 4500? Believe it or not I am of the same opinion about knowing something was done right. I just hate throwing good money after bad. I want to start using this pickup to run back and forth to AZ and tow a medium sized fifth wheel and I abhor the idea of slinging fifth gear and running 1000 miles or better home in 4th gear.
  12. I’ve never physically been inside of one these, so bare with me please. If there is a failure won’t the gear and nut be out of there original position? This should allow plenty of shaft access for a cut off wheel? Thanks
  13. I work offshore, so I’m not able to get all the info required at this time to fill out garage. I’ll update when I get home. Thanks
  14. The only thing I see it complicating later after a failure is taking it apart. The shaft is junk from day one, so when it comes time to take it apart, cut it in half with a cut off wheel remove the damaged section to complete disassembly. Am I missing something?
  15. I’ve been kicking this around for a few months and from what I see the after market replacement nut packages don’t really hold up any better than original equipment. This is why i thought id weld the original nut instead of buying the aftermarket junk. I started a new thread on this instead of hijacking this one
  16. I know this topic has been beat to death. Sorry! I just bought a 2001 4 x 4 five speed with the NV 4500. At this time there has been no failure. My thinking is open up the back of the transmission verify torque and weld the nut to get some more life before an ultimate rebuild. Maybe that would be a waste of time and effort? TIA
  17. Thank you
  18. I know the proper fix is rebuild with upgraded shaft, but I thought I’d be alright to weld it (gently) lol, get some more miles out of it , then when it ultimately failed pull it and do it right. I should just pull it now and do it? At this time it hasn’t been touched. No previous failure
