Everything posted by kbf98520
Upgrades
What are the benefits of 35 spline shafts, high pinion housing and 3.73 ratio?
Pilothouse/RAM3500 build
I just scrolled this whole thread. Amazing work. Thank you for sharing your time!
Upgrades
5 u joints, three shafts, unserviceable wheel bearings, differential and transfer case spinning all the time needlessly was my main concern. Increasing efficiency was secondary. That being said, I like the idea of a hotter thermostat. I run diesel engines for a living and have alway understood that they are more efficient when ran a little hotter. A little bit at a time. I have a few more upgrades planned then I’ll be looking to bump up horsepower. Turbo, injectors, tuner 😁
Upgrades
Can you tell me more about the permanent set up to eliminate the CAD please?
Upgrades
Beast came with the solid axle?
Upgrades
I’m pretty sure that’s what it is . Haven’t had time to look at it yet everywhere I look is a project and pickup has slid back down priority list. 😂. I haven’t done any thing with vacuum lines on axle in fact I don’t even really understand what the do as the 4wheel drive manually engages…. Posi lock? I know not Thanks
Upgrades
Finally got the Spyntec free spin hub kit and Autometer pillar gauges installed. I’ve always hated the idea of all that hardware turning up there all the time. I rarely need 4 wheel drive . A lot of work, glad to finally check these off the list , I’ve had the parts for longer than I care to admit. It seems I’ve dislodged something in the process though. Cruise control quit working. The light comes on ,but no function
After market gauge lighting
Good afternoon. I’m in the process of hooking up Autometer gauges on pillar pod. I’d like the lighting to illuminate and dim with the factory gauges. What is the best way to accomplish that?
FASS Install
Thank you. I will do that. Too busy this weekend and headed back to work for probably 5 weeks Monday , so it’ll be September before I can get this done, also gauges, exhaust,one piece drive shaft and free spin hubs next. I’ll post with results. Kevin
FASS Install
Yes.
FASS Install
Great write up, thank you for posting. This new system is powered directly from battery and ignition circuit from fuse block in cab. It has an inline relay in the wiring harness included from FASS. The OEM plug that powered the block mounted lift pump is now disconnected
FASS Install
I already bypassed original filter housing with plans to ultimately remove it. The heater isn’t really needed here where I live .New pump works great. Went with Fleece Sureflo sump and sending unit . Great setup
FASS Install
So, wiring a relay into the old lift pump circuit will eliminate a code from now unused block mounted lift pump. I’d like to just remove filter housing and lift pump.
FASS Install
There is an inline relay with the FASS supplied wiring harness. I know not what this does. I assume I will get a code from the now disconnected block mounted lift pump. Do you know of anything I can plug into that to prevent this?
FASS Install
I’m finally getting around to installing a FASS Titanium unit (that has been on a shelf for quite a few months) on my 2001 manual transmission 4x4. This pickup still has block mounted lift pump. I’ve disconnected electrical plug from the factory lift pump . Where should I put the fuel line from new pump? Inlet of preexisting block mounted filter or inlet side of injection pump. FASS instructions say directly to injection pump. I had some previous advice that said to connect it to inlet side of filter housing. What are the advantages and or disadvantages of either? TIA . Kevin
New High Idle Switch
Is there any way of telling if it has been enabled?
Ok, thanks for that. I’ve read some places that an ECM update is required? This is a dealer thing?
Do I need a Quadzilla tuner for this switch, and when I get one in the future is this switch necessary?
How long do you think the used truck market for good 24 v 5.9 Cummins 2 nd gens will hold out ?
Lol! No,just busy. Bone stock, unmolested, well serviced 150000 Can’t wait to get home. Huge pile of parts I get to throw at it
Just paid 20000 for one in Coeur D’ alene
Lift Pump Suction
Thanks. I appreciate the help. I’m away from home at work now. I’ll take a look when I get home. Hopefully I can 90deg off the return internally to keep it away from suction
Lift Pump Suction
This is almost an identical OEM sending unit replacement. Something that has been perfectly functional for the previous 150000 miles. The whole idea of buying it was to have a good reliable suction without drilling additional holes in the tank.
Lift Pump Suction
That’s good to know. Thank you. I’ll plumb the return in elsewhere
Lift Pump Suction
Fleece Sure Flo Performance Sending Unit. This is the ticket. Spendy, but looks like a great set up. Plus eliminating some very old parts
Anyone close have a smarty I can borrow?
Don’t count your chickens before they’re hatched it’s February😂😂😂
