Lund1990
Monthly Subscription
Everything posted by Lund1990
  1. Well, i took a video to upload and show what it does. But it won't allow me to upload it no matter what I try.
  2. It definitely takes longer. The truck it came out off of was a pulling machine tho. It wasn't quick by any means, pulled like a freight train tho
  3. That's the exact reason why I'm still running the stock turbo. It's nice and snappy. Donor truck was set up for towing large loads and doing pulls. It also had propane injection before. The smaller turbo is an s300 variant. Haven't done much research to find sizes. I've actually been contemplating adding a belt driven supercharger too, just for the instant boost. I saw a video where a guy had taken one from a gm 3800. It actually seemed like it quirked pretty good. Plus it provided boost at all times, even just a little at idle.
  4. I have a pyrometer and a boost gauge. It's a 24 year old **** box. I'm not always the nicest to it. But the previous owner was definitely harder on it. Stock manifold was pretty damn rusted too. The 3 piece came off truck with compound set up and never had any problem. The compounds are going to go on this truck I think, after it's warm again. Bigger one is a 109mm off of a 14L Cummins. It's all just money, right?
  5. So my stock exhaust manifold on my 2000 cracked the other day. I have a 98 with a cracked block that I'm robbing the manifold from. The one I'm robbing is a 3 piece ATS. Problem is, ATS manifold has 4 studs in it, while the stock turbo has 2 studs in it. Which one would you guys drill out the holes on to get them to mate together? I'm not ready yet to put the compounds from the donor truck on my 2000 yet.
  6. Thank you. I didn't find much online either. I was just hoping someone had had this happen before. Seems like it would be something a vehicle would do for the security, but i have a black key for truck.
  7. Not that. I own 3 cummins I know about grid heaters. They actually turn off and back on. Like 1 second each way. Does it for a few minutes them stops.
  8. I have a 2004 crew cab short box that when I start the headlights, tail lights, and blinkers all blink for a few minutes. Any idea what the cause is?
  9. I just put a stage 6 dual disc clutch from south bend in it over the weekend out of my truck with cracked block. Bearing seemed fine so I used it. I did get it all pulled as 1 unit, actually balanced on the jack very well. Bearing still seems fine. I think the squeal I'm getting is from the pressure plate fingers not having enough pressure against the Bearing when the clutch is engaged fully. Pivot ball is slightly worn. I put a washer behind the pivot ball, and put the new Bearing in anyways. Hopefully button it all back up tonight before work, bed is calling my name.
  10. I need to quickly getbny throw out bearing changed before leaving for a trip tomorrow. Thinking of I pull both cross members that I should be able to pull the trans and transfer case as one unit with out draining the fluids that are brand new. Has anyone done this?? Is there enough room? I have a HD trans jack, so I'm not worried about weight.
  11. I was towing a trailer last night and noticed that my brake lights were not working. I've dug into it a little bit. Ive tested all the fuses and they're good. I've done continuity test on the brake switch and it is good. i have turn signals and 4 way flashers, but i don't have any brake lights. Any ideas?
  12. i was moving my 2004 2500 around today, i noticed that while i had it running the headlights and taillights were blinking about once every second. I didn't have the headlight switch on even . Does anyone have any ideas what could cause this?
  13. Lund1990 commented on ty_lowcountry's Cummins article in Cab Interior
    I replaced mine with a steeI replacement from Heater Treater. Never have to worry again.
  14. There doesn't appear to be link for a 2000 FSM. So do I use the 99 or the 01?
  15. Vehicle Nickname: Financial Mistake Date Added To The Garage: 2024-05-29 Garage Link: Financial Mistake
  16. Every website has an opinion one way or the other on the trans heat exchanger. So, what is the consensus here? Do I replace it or delete it and put a under bed cooler on it?
  17. It's a 2000 Ram 2500 single cab long box. Cummins with a nv4500. Standard 2 bulb headlights. Not a Canadian truck. And the only mod to the fog lights would be the wires were cut when the bumper was removed and soldered back together.
  18. So I've noticed a few times when I get back out to my truck from going in the store that my fog lights will be on randomly. Switch off, no headlights. Just fog lights. Any ideas what the cause could be?
  19. This one is a 2004 Auto. I've got a 2000 with an NV4500, and a 98.5 with a built NV4500, stage 6 south bend clutch, compound turbos, and a cracked 53 block....
  20. After reading this I decided I should check if it was in the truck already. Turns out it is. Just gotta use the cruise control buttons. It can be set anywhere between 1,100 - 1,500 rpm's.
  21. Alright. I've heard that the Smarty tuners for this generation also VIN lock, so you can't just have someone use theirs to flash it. Any other tuners that have the capability to flash the ecm?
  22. Has anyone tried the high idle set up that is for the 2nd gens on a early 3rd gen. Just curious about it before I mess something up on my truck.
  23. Yeah, buying another 5 pack. It's for factory plugs and looks to be factory wiring, at least on the 2 I got changed so far. Had to do some surgery to my roof. My guess is that they were installed by a dealer, most likely a specific request from the original owner. Guess it's true, you can't fix stupid.
  24. So I ordered a pack of LED cab lights last fall and just now I'm getting around to installing them after I got thr 2nd 1 on I realized that my truck has 6 cab lights. All the kits are for 5. So I was just wondering if having 6 was an option or if someone installed after the fact. The ones I'm removing seem to be factory.
  25. I guess I was kinda thinking the same thing. I do have an in cab warning might that runs off a T in the fuel line between the factory filter housing and the vp44. But it evidently doesn't work as I found today that the ground wire isn't even hooked to the sensor.
