Everything posted by PilotHouse2500
turbo output to firewall allowable gap
In my project I finally found a 90° down part that fits. The gap between the 90 and the firewall is about 0.700". If I wrap the 90 will that be enough of a heat reduction so I don't discolor the paint (or damage it) for that gap? Or do I need to create a bigger space behind that?
Cobra style exhaust connection to turbo
I'm potentially short on space for my project build between turbo exhaust and firewall. I ran across these types of parts for 4bt engines, I have not confirmed anything for 6bt....has anyone used or seen these in the wild? https://www.dieseltuff.com/product/4-cobra-head-hotpipe/
add on cooling kit for back 2 cylinders
Yah, I really don't know if I need to worry about it. I'm not planning on pulling much load really and it's pretty flat around here. Was just wondering your inputs on this before paint. Appreciate the feedbacks!
While I was out in CA for a truck show at my buddies ranch, I got into a conversation with a gent on his 12 valve where it was starting to get hot over time. Another guy suggested some add on kit that pushed more coolant to the rear 2 cylinders. Question for the group her is this: is this worth the add on? If it IS, I want to make sure to account for this in my build NOW while I can move things around vs. after teh build is done and ends up being a mjor issue. ANd if it IS worth it...who might sell this kit? I think this might be for RV aplications? maybe this? https://puredieselpower.com/Cummins/Dodge-Ram-5.9L-6.7L-Cummins-Engine-Parts/94-02-cummins-cooling-kit-improves-coolant-flow-to-cylinder-6.html?gad_source=1&gclid=EAIaIQobChMIqKXny6vJhQMVxDjUAR2TAgDmEAQYAiABEgI2rfD_BwE
Pilothouse/RAM3500 build
Seems I forgot to upload a bunch of stuff! Wood working season is upon me so even slower than normal for a while. Paint WILL happen this summer/early fall, so I HAVE to be ready! Might have some long days ahead of me to get everything done between wood and truck. Meanwhile, inner fenders done, hood ornament mounted, shift boot mount in, fuse block mounted and radio mounted.
1996 3500 4x4 drum to disc brake rear conversion
Has anyone done this conversion? If so what did you do/watch put points/pluses/minuses? I tried to search this but either my search terms were bad or I'm blind....
shift boot location on tunnel
Yah that helps a ton to see where the boots "land" on the sticks. Appreciate!
Just checking to see of you had a chance? I put the boot on and did my best guess, I CAn cut it off to remove if I'm way off. I do think an issue is how far apart the tunnel height is off the top of the trans ( I might have to space it up). Still hoping to can pull thru for me.
well I poked at it the hard way....I put the parts on and tried to find hte best location possible. Seems that I needed to pull the mounting ring back a bit (off center FTB now) to make things "work". I'm also guessing I might have the tunnel lower to the tans than woudl be stock on a gen 2. So back up question, can someone share a pic of a gen 2 shift/TC boot installed?
My Personal Opinion
Still thicker hair than me!
A few steps closer....taking forever it seems: 6 hours days working on this thing and still not done! Hopefully, today I can call passenger side "done".
Right, and I plan on doing that...but I need to know where to weld a "ring" (thicker version of black thing in pic) to screw the boot and cover plate to.
That's ok, kinda figured right now it'd not be you. I don't know if it REALLY matters TOO much for overall location. I was planning on centering on the gear shift and let the TC fall where it may. I just don't know if that is a problem or not (cause I won't know untill stuff is welded up and painted), just hoping someone has a number/idea before I start making parts become one via MIG.
My Personal Opinion
Good to hear you are keeping up on things and a good attitude!
He's SUPPOSED to go in for paint this spring....frantically trying to find the energy/time to get everything done in time. The list keeps seems to keep growing sadly instead of shrinking! And I have a dockett already of woodworking projects I need to start on this spring as well (gotta pay for this all somehow as inflation is eating my main job check pretty efficiently). So figure about 1 year or so after I get parts back from paint I hope to have him on the road. And I AM planning a drive out to CA to visit my buddy for his car/truck show and hope to loop up thru the NW as part of the trip.
been a while for an update, so here you go: Power for front doors AC condensor rock gaurd foot pedal head light dimmer Turbo gauges holes punched in Cenrter console
My Personal Opinion
Glad you have a good team buddy! One of my old neighbor is going thru some C as well and a good support staff makes all the difference in the world. Sorry to hear the Neo isn't an option. Hang in there and do all you can, lean on those you can and keep as much smil eon your face as possible. I promise to hold a Zoom here to look over my project by the end of the month.
My Personal Opinion
Good people seem to have bad things happen...it sucks, but I am glad you are finding a way thru it as best you can. While not everyone will appreciate, do what YOU gotta do for YOU. Per request I suspended my donations and will watch for when we can start to help out again, websites aren't cheap and I fully want to help support this community. Drop me a PM if you ever wanna set up a call and check out my old dodge insanity stuff.
I know this is sudden but...
I'm heading "up north" near the Canaukastan border this week later to hang with some friends in their shack to have some fun w/o power or running water.....always a blast, so I won't be around till next week for any zoomy calls. If, after that, as I said anyone wants to zoom my shop and do a walk around my project I'd be willing. Glad to hear you in better spirits. I can sympathize your situation to a degree. My wife was in 4 accidents about 2.5 years ago. We count one accident as 3 because it was multi car and she took 3 impacts. She now has TBI and her (and my) life has changed dramatically. She's luckily still "there" but physically she can't do her old job, do house chores, drive at night etc. Severe concussions suck. It can wear on me as well with all the extra duties and understanding it takes now repeating some things as she doens't remember everything as she should. So I totally get where you are, just know people care about ya, are really hoping that you can find a new "normal" and keep a smile on your face as you move forward. Depression is insideous and remember there are help lines available if no one is around in your personal life to talk to in a dark hour.
if you get despaerate, I could zoom a call and walk around my project truck and you all could laugh at my insanity.....beyond that, I'm not too deep into the engine (yet) to get into a 6bt discussion.
It's been awhile since yu last visit here. Updates: outter body work all done as far as I can go. I have started interior work and figuring out how and what I want layed out in the cab. So some shots of the fender "rivets" which are now carriage bolts turned down to look like rivets, NOS arm rests for the people doors, and under dash panels built that will hold AC vents, AC controls and a radio.
Just saw this. Your attitude is a wonder to behold, too many would fold up and give up! Keep that attitude going and do all you can do in life!
