IW378
Everything posted by IW378
  1. Those chocolate covered paydays are one of the best candybars ever made..5th ave holds rank though.LOL
  2. If the fass ddrp is 225 bucks you are only looking at another 175 bucks for an airdog with a lifetime warranty.Luke
  3. Okay since I'm a newb i'd like to know what you guys keep on hand for an emergency repair. Here's what I have underneath the back seat. End wrenches up to 1 1/4" socket set up to the same size. Misc screwdrivers and pliers and an extra fuel filter.Is there anything else that would be a must have besides extra ammo?? LOLLB
  4. Thanks for the good tips.:thumbsup:
  5. It did come with an extra spring. A 17 pound spring. I guess that gives me something to mess with next weekend
  6. Mine does not actually hang lower than the skid plate. It just might be the angle of the photo. I will snap a better pic of it tomrorrow if I get home before dark.
  7. Yeah Buddy.. 15 psi is good stuff. LB
  8. It might, but it will be a pain in the rear end. I did not want it mounted outside the frame. And on a short bed 4wd mounting it inside the frame between the tank and t case there is not enough room to work on it like tightening the fittings and such. I also re did the wiring harness that came with it by cutting it down and re soldering to make it shorter so there's not alot of extra wire looped up. LB
  9. Not the one I got. From what I've heard the mount like moparman got is not available anymore ??. Also I had to hunt all over town for more 90 degree fittings to make it work.You will need the extra 90's if you mount square to the frame instead of parallel to get the hoses pointed in the right direction.
  10. Mine came with 2 peices of plate to sandwich the frame for a parallel mount. But I could not get a good spot to mount it parrallel to the frame without it hanging too low.
  11. I used one of the plates supplied to weld on a piece of 3/8ths flat bar and a gusset so I could mount it square to the frame between the tank and t case. . I have a half inch gap between the tank and the unit and plenty of room to get to the plugs on the t case. I used a russel fitting for a good spot on the vp to monitor fuel pressure.
  12. I installed my AD today. Took about 5 hours and I had to make a home made bracket. I now have 15.5 psi at idle and 13 if I get my foot to the floor.
