Diesel
Everything posted by Diesel
  1. Bad connection will do strange things. It threw a code on him. Didn't throw one on me.
  2. And yet it seems to have corrected the problem.
  3. Thanks for all the replies. Very informative. But I think my injectors are good. Check my thread" Maybe it isn't the injectors" to see whats going on.
  4. Well, heres an update on my injector issue. One of the good things about buying a truck that someone you know was the last owner is that when you text them about your problem they call you and say, " you know, the truck did something weird one time and you might want to check.............." So what I was told to check was the fuel pressure sensor connection. Unplug it and plug it back in. I also blew in it for good measure. And wouldn't you know it, the truck has been starting good the last 6 days. Knock on wood, but it looks like it wasn't injectors after all.
  5. So are you thinking these "new" injectors are just remans?
  6. Thanks Mopar tech. If I can't figure out what kind of improvements over Remans the BBis and the marine injectors are I'll probably go with Remans. These marine injectors sound like they might be good, the BBis are kinda high you want to know the truth. I don't know if I can afford em or if I even want to. Shoot me a pm with a price if you want. Do we have a pm function?
  7. That's the second time the marine injectors have been mentioned. Other than the 50 hp gain, why would they be better?
  8. So give me your thoughts. I called Snarty and asked about the BBis and if they had cured the injector failure problems. They wouldn't commit to a yes saying there hadn't been enough used to tell. Said 2 micron filter was the answer. So I took that as a no. So tell me what you think woul be best and why.
  9. Yup. I was hoping for something else.
  10. I havnt been able to check the nuts yet, but it seems to be getting worse. It did start normally a couple times, like when I was gonna show my wife, but then it started up again. This morning it started and idled at 500 for maybe 5 seconds then jumped up to 8-900 then started bouncing around 7 to maybe as high as 1100. I ran around to exhaust and yep, smoke. Another thing, something sounds like it's making noise around the injector pump. Sounds like a tapping. So, definitely injectors? Or injector pump? Or both?
  11. OK. Thanks. I'll check the nuts Tourqe and if that isn't it I'll be able to run it for quite awhile like it is till I can save up for new ones?
  12. That's what I was afraid of. So I have 2 questions........ How long till it completely craps out or I damage something? How hard is it to change the injectors? And a 3rd question. How do I change them?
  13. This weak the truck started starting hard when it is cold. Truck sits for 12 hrs between driving. It will stumble at about 500rpm for a couple revolutions then build up to normal idle rpm and runs fine. If I shut it off and restart it starts fine. Ambient temps at startup have been between 69 to into the 80s. Any ideas?
  14. Hey, sorry I missed this till now. Been busy. Somethin definitely isn't right. Have mine on 5 and when I put my foot into it I am makin all kinds of ruckus. Might want to go to Brian's forum and get some answers. You should be blowing smoke and spinning tires.
  15. I'm just wondering if the 06 has the silencer ring. If it does and I removed it would that help the turbo spool up sooner?
  16. I think Sarah is making the trip out to the middle of the desert right now.
  17. Awesome.. I guess the old ones just got old?
  18. Ya. Definitely let us know what you wind up doing.
  19. Ya, I'll just get the regular gauges.
  20. I'm not saying you don't know what you are doing. I'm trying to understand why you are doing it that way. But I think I might know why now. The trailer doesn't turn DC to AC on its own. I think mine has a built in inverter, but I could be wrong. I'll have to check that out.
  21. I would say it must be a press in clip then. Kind of like the plastic license plate clips. Why not go to Dodge and ask? They can show you in a blowup diagram exactly what it is.
  22. Well, if it is a clip you can get one at any parts store, another bolt also. Then you just slide the clip on the support and put the bolt in. Looks like this.
  23. OK. I've got some questions about this. Why are you running it through the RV? Why not just have it charge the batteries and run off those? Why the need for the inverter and the switch and all that? I'm interested in this idea thinking I could run the RV off solar during the day, and only need a quick boost with the generator in the morning and evening to keep the battery up.
