catnhat
  1. I will try that next
  2. Didn't think of that. If it did go bad wouldn't something else not work to
  3. Started off with finding out my heater core started to leak but the stuff should be at the house sometime within a week. But as of this morning I have know low beams but I do have high beams. So after worked stopped and picked up a new headlight switch from my local junkyard and that didn't fix it. I have checked the fuses and not really sure where to start next.
  4. I had a 1/4 inch Line on my old 98 and on this 01 I have 1/8ich line and in my experience the 1/4 inch was was easier to get the gauge not to bounce.
  5. Thanks that's what I was trying to do and I wasn't sure of the bigline kit would do it
  6. It's been about a year since I installed my fass 150 and it's about time I install it into the factory fuel filter and I am a having trouble finding the correct fittings to make it work. I am sure I'm just overlooking something but what exactly do I need
  7. A little plumber's tape never hurt anything. I use it on just about all pipe threads
  8. I have one but never put it Just sits on the bench. I have had a ez on my last two trucks.
  9. It will give the same power as the ez without the wiretap not worth the extra money if your never going to use the pump tap
  10. My old 98.5 had a little bolt on the top that I would open to bleed it out but the 01 has a different filter bowl that I can't do that anymore.
  11. I used a bucket and I had the crack a couple injectors loose to get mine started again
  12. Took about half a day for me to do the vacuum pump. It's not hard I found a pretty good video on YouTube. Could it be oil?
  13. Had mine down to -20f a month ago with a fass and no fuel heater plus I forgot to plug the truck in. But on a side note I have also poped my fass fuse before it is around 10 below when I did it ran inside to the gas station came out and had zero pressure. Changed the fuse and down the road I went.you have to have a fuel pressure Guage. I get funny looks when I tell ppl that I have a fuel pressure gauges in the truck
  14. All I got was a sheet that said main relay open 65
  15. What does that code 65 mean is the module bad or is it something I can fix
