Everything posted by W-T
Factory lift pump & After market lift pumps Caution !
Mike @JAG1 excellent incite...the use of a toroid core with multiple winding's to build maximum lumped inductance is an additional way of blocking undesired or extraneous signal on a DC supply line. Many computer monitor manufacturers will have an "egg" on the multi-conductor cable running to the computer mainframe. Much of the high speed switching data on the line can and certainly does radiate undesired digital-hash. Just as an analog DC motor does in run-mode. Here is an example of a home-brew AC line filter constructed around a 2 1/2" toriod core. The properties of the core's "mix" elements (iron,nickle,cadmium) vary and is chosen for the frequencies or band of frequencies targeted for suppression. The amount of "windings" present in this example (core value unknown) generally indicates higher frequencies are to be attenuated and the amount of inductance is nominal but, not enough for our needs in suppressing the trash of aftermarket Lift Pumps drawing 5 to 8 Amps of current. Some of the larger aftermarket Lift Pumps may sink as much as 10+ Amps of current and now we're talking about some real power factors. Here we have an improved choke wound with #10 enameled solid copper that would be capable of conducting larger current demands with very little loss because the wire size has less resistance. This is important to us because we want the maximum voltage to be supplied to the DC motor and not dissipated in the form of heat due to the series resistance of the line or wire making up the choke itself. Here we have a bulk choke constructed on a larger toroid doughnut with tightly packed turns and NO overlapping. This is approaching "real" levels of inductance to virtually "choke" the heck out of the chicken..... @dripleyis not included here. The goal of a bulk DC choke is to build it as large and with as many turns as possible to increase Inductance. The larger the inductance the better it is for low to mid range frequencies of suppression interest. This home-brew choke needs to be packaged to prevent damage and water/snow contamination. This home-brew choke must be located directly at the "noise source" (LP motor input leads) and secured for physical integrity. The use of "Fair-Rite" beads placed onto the DC leads will be of little assistance in our goal of high current DC choking. In a "two wire" run from the power source (plus and minus) you would build chokes for both lines. Yes again @JAG1 Mike...extreme attention to the way a LP mount structure is physically attached to the frame is critical ! The flat surfaces mating together should have NO paint insulating the two flat structures. Put "NoLox" grease between the two surfaces and tighten the mounting bolts to "squish" the grease and protrude outward so as to not allow moisture to collect between the two mating surfaces. Never expect a "bolt" or "screw" to act as a proper ground when you're trying to suppress RF hash. The larger the surfaces are in mating together will provide the best integrity of noise suppression. The noise "is" RF...it does NOT FLOW within a conducting element (wire) it FLOWS on the SURFACE of the conducting element (wire)... it is called SKIN EFFECT... the paint/powder-coating must be removed on ANY MATING SURFACES of a "noise generating" device (DC motor). All the aftermarket Lift Pumps are packaged beautifully. NONE of them have CONTINUITY between their own body elements. During the initial by-passing procedure earlier in this thread I NEGLECTED to highlight a VERY IMPORTANT issue ! @JAG1 has brought this to the forefront. I apologize for this oversight... You must disassemble the entire aftermarket LP unit and clean all mating surfaces to remove ALL ANODIZING and PAINT at EVERY contacting/mating point. NO continuity means NO suppression. I am so very sorry for having left this out of the initial documentation. Please note: the Original Carter LP HAS NO PAINT IN THE ENTIRE CONSTRUCTION of THE DEVICE. I used a Dremel Tool with small bits to "scarify" every hole where an assembly screw/bolt passes through to join another piece of the modular body construction. The beautiful "Anodized" surfaces of the fluid pump body as it mates to the lower fully "Anodized" water separator and fuel filter housing is FULLY NON-CONDUCTIVE ! I'm so very embarrassed to have NOT provided this imperative aspect. Sorry for my major error...there is no way around this...you must completely disassemble the LP platforms to restore full body continuity and then because of the full disassembly procedure, it lends well, to perform the "by-passing" procedure at the motor armature end-cap assembly. I am just mortified by this omission ! @JAG1 Mike...I am sorry... it was my original observation so long ago that drove me into this comprehensive refurbishment of this $700 pain in the A... if I could regain my composure with just a bit of saving grace on my behalf...NOTHING WORTH WHILE IS EASY...this aspect is ONE OF THEM. Indeed, our conversation has come to light in my cluttered mind and I now fully recall my primary reason for this entire thread. MY pump was a pile of junk electronically the day it arrived at my home. It was so bad, I called the manufacturer and spoke directly with the owner of the company. He was a very kind and gracious man. Our conversation continued for 3 hours that day. He openly informed me that his pursuit was into the US Military diesel vehicle contract part procurement program. When the subject matter was fully understood and how the fix would be incorporated into the package the task became daunting. The exchange was professional and enlightening for this gentleman . The aspect of having this product pass the "specification" hurdle for demanding US military standards for electronic compatibility... he then admitted to me that this concept had not been considered. The next day I was offered employment on the Engineering staff of the company...I was honored however: I did not wish to relocate. Again...I am sorry for dragging all my fellow CTD enthusiasts through the mud...credit goes to @JAG1 for surreptitiously stirring the pot of a failing biological hard drive. ...in the future I will have my notes compiled prior to annoying everyone. With humility W-T
@dripley thank you Sir, yes, this situation is very long term...the clean up is commencing between rain however; it will be years before this area is even close to being normal again. I'm also limited with internet...I'm using my iPhone HotSpot to be able to participate here. Cheers
View full Cummins article
The subject matter has been discussed for years and all diesel enthusiasts/owners know how important it is to maintain proper levels of fuel pressure via the "transfer pump" or Lift Pump for reliable operation. There are many requirements that each owner/operator may wish to achieve in replacing the OE Carter or perhaps making an aftermarket selection. Notably, most have had the rude awakening of a failed VP44 following the failure of the Lift Pump in a too late scenario. The cost of a VP44 compared to the Factory (Carter) Lift Pump is considerable and many of us have learned the hard way. The general consensus among the vast majority is to eliminate the factory OE Carter pump and invest in a robust Class 8 aftermarket system. There are several companies that offer such devices with different performance levels and packaging. Many, come complete with new 1/2" fuel lines, mounting structures, fuel fittings and electrical control harnesses. Some companies offer more modest devices with a budgetary aspect at minimum level. All of this becomes apparent when a conscientious owner/operator begins the research to purchase a new device or system. I for one have stopped reading "Lift Pump" threads because it's so very painful...and I've already seen so many stories of the same old blah blah blah! No, I am not being insensitive to a fellow CTD owner's plight...after all, this is most likely a "new to Diesels" type person. The post is reaching out to the "experienced" diesel enthusiasts for suggestions and perhaps constructive feed-back, prior to making that large investment. Confidence from fellow CTD owners in what they may have purchased or installed goes a long way with the new guy or lady looking for an answer. For just a moment allow me a little latitude...Oh God! Not another Lift Pump story ...Yes but, not what you might think. This will drill-down in a different manor so, please bare with me. The factory OE "Carter" is such a little peanut-whistle why did Dodge do this? The fact is, as many know quite well, the decision was Daimler Chrysler who dictated to Cummins to provide the complete CTD engine package as a drop-in module. Carter's specifications states that, "this pump is to be located within 18 inches of the fuel supply"...it's sad to know these details greatly after the fact. This detail was covered 20 years ago on nearly every diesel website worldwide. This led to the unfortunate degradation of the Carter transfer pumps reputation. In actuality, the Carter LP (lift pump) has excellent design characteristics! At first glance the appearance seems a bit "puny" but, let's look at some of the "not so apparent features"... First of all, Carter is a very large world-wide company who provide a vast selection of produced articles. They also provide excellent technical documentation regarding the application of their products in numerous industrial devices, automotive, marine and aeronautical systems or platforms. Electro-mechanical pumps of this nature, are just a single product that they produce... In our application, CTD's are at first, supplied copious amounts of diesel fuel at acceptable levels to operate the engine and provide flow-through for critical cooling of the VP44 in return to the fuel tank. This is "how" the designed system was to perform. We know as experienced CTD owners that this was not always the case. Many of us know the error of mounting this little well designed pump nearly 10 feet forward of the fuel supply (not to specification of Carter Inc.) and ask this little pump to draw fuel through a small 1/4" line and....force the liquid through "banjo-bolt" fittings as delivery to the VP44? Wow...it's an unreasonable expectation for an electro mechanical pump, that most likely, costs less than $20 to produce in the Philippines. None the less, how many of us have had the occasional chat with a CTD owner (who knows nothing) that tells you they purchased the 2nd Gen new, he has 187K miles and has NEVER replaced the VP44 (he doesn't know what a VP44 is...you just taught him the word) and NO...he has never put a fuel pump into his truck! Yeah ! You know what I'm talking about ! How can this be ? Well...I guess some folks are a lot more lucky than I am... heck...this guy doesn't even know about 2 Stroke for lubricity,... credit our GodFather @Mopar1973Man This photo is well known as a starting point. Also, a depiction of what Cummins had to do to appease Daimler Chrysler's request of a "drop in module" CTD Okay...what is "a well designed pump"... even if it is not mounted correctly? At Carter, where they have been doing this longer than any of our familiar after-market LP suppliers... please note: 1... A fully enclosed hermetically sealed electro-machanical device that allows the liquid fuel to act as a cooling medium and fully immerses the active armature of the 12 volt DC motor to never exceed the temperature of the supplied liquid (diesel fuel)...because it is "airless" (hermetically sealed) there is no ignition to cause flammability. It's liquid cooled ! 2... The entire body or "encapsulation" as hermetic, provides absolute closure or isolation of the motor-brushes as they kiss the surface of the armature in run condition. This is very important as a DC (direct current) motor with carbon pile brushes act as a wild uncontrolled sparking noise source generator !!! This is a normal phenomena of any analog DC brushed motor. A given manufacturer of brushed DC motors, depending on purpose, will take steps to "silence" the electrical (RF noise generation)...the term "purpose" needs clarification... "if the motor is a "CCS" continuous commercial service (runs all the time) then, additional electronic filtering or "shunting" of the armature must be provided. 3... Carter Inc. employs RF Engineers (BSEE graduates minimum) to accomplish technical requirements when contracted specifications are to be adhered to for final product production. An expensive platform in any industrial production would have a string of engineers along with design engineers specking' components or assemblies that will be encapsulated within the finalized product. This occurred in "our" beloved CTD's with electro mechanical LP's....the Carter is "RF quiet" for continuous run condition. Let's examine the electronic terminals of the Carter LP Note: The plastic weather-guard assembly directly attached to the full metal housing that contains the + & - 12 volt DC ! 4... This connection point provides the direct current to power this LP. I wish you to fully understand what you're looking at. As viewed you'll note "both Plus+ and -minus" is provided at this connection point. You must also NOTE, the + and - are arriving directly from a single "pair" connection of both + & - .... I know you'll think I'm stating things "twice" and I want you to know this is an attempt to be a "balanced" feed. The housing of the pump is fully DC grounded when it is attached to the mounting bracket. In a "balanced" feed the "minus" or "negative" is NOT directly at chassis ground...it is merely + and - of the source (12 volts DC in our case) the body of the pump IS directly grounded but, the "source" is isolated from the pump body. Put your Ohm meter on either terminal and touch the pump body....there is NO direct DC continuity in a "balanced" source. This is a sexy way of making things very "quiet" electronically. Professional audio studios are fully balanced systems using "Cannon" connectors with three terminals. One is "plus" Two is "minus" and Three is "shield ground"....hence, balanced and NO Hum or Static noise. (Hey...those guys at Carter make a quiet pump...it's wimpy but, damn quiet) Okay...now let us examine what is going on internally on the back side of the connection point. A careful surgery, with hack-saw in hand, to remove the hermetically sealed body cover and expose the multi-octave filter or "shunting" design of this Carter LP. The double sided epoxy circuit board with modern surface-mount chip capacitors is excellent. This board is located directly at the input of the 12 volt source with virtually zero component lead length (surface mount) to provide shunting of the make and break contact that the brushes are doing directly at the armature when in "run" condition. This DC motor is virtually by-passed or shunted for any RF noise or "spiking" all the way passed 450 MHz! NOTE ! I did say "spiking" or should I say... "ripple"... this is a source of nasty "ripple" directly connected to the entire 12 volt DC rail of our beloved CTD's Quality engineering of analog DC motors remove such garbage before it is introduced to devices such as aircraft, fighter jets, military assault platforms, nuclear submarines and civilian automobiles. There are many preferred after market suppliers of fuel pumps or systems available and many are quite note worthy when it applies to providing solid reliable fuel flow. Many of these platforms exceed the requirements in "fuel flow" for the average diesel enthusiast. Sometimes choices are made because the owner has future plans of building enhanced performance characteristics. Some choose additional GPM for the insurance of added cooling by the "return flow" system design. All of the after market manufacturers of the upper end platforms do this with ease and price the devices accordingly. Caution in selecting any device that may cause unknown after effects in any mobile platform. The CTD 2nd Gen, is something I've looked at carefully for many years and I've made concerted efforts to correct some electrical over sites for the betterment of these noble platforms. I too have made large investments and the after market LP selections are not cheap. I was exceptionally disturbed when I successfully installed an after market LP system. The extreme effort to correctly and cleanly install the system along with all the cool JIC fittings and complete the project with pride that someone may examine my work was all accomplished. Then I shortly discovered the absolute short comings of my nearly $900 investment. I blamed myself for not test operating the device on a test bench and viewing the horrendous RF interference HASH that took out everything from 500 KHz (just below the commercial broadcast band) to well above 500 MHz. Is this important to you?... It is and perhaps it has not become apparent by the way such broadband RF interference manifests itself within a closed stand alone 12 volt system. To make these statements to you, the reader, let me be clear, I use and own a Hewlett Packard 8921A Digital RF test device, at $24,000.00 ...one must be "a fully certifiable crazy idiot" to have this along with a Tektronix 200 MHz 4 channel scope...and someone asked..."Do you need such instruments to look at $25.00 DC motors"...no but, I'm fully confident in my findings. Let's take a look at the much enhanced DC motor of an after market LP...it is irrelevant as to the manufacturer...they are all the same. This is an initial basic disassembly procedure that needs to be performed. It's very easy to accomplish. Once you have the cookie opened you'll be able to view the end-plate where the carbon brushes reside in their respective holders. Many of these devices and earlier models vary by design in physical form but, they are all the same in regard to an end-plate with brush tube holders. Here is the end-plate removed from a different LP unit and we can see the very minimal by-pass engineering of a single .47 Mfd mylar capacitor directly across the two brushes. Note, the lead length. This is typical of an inexpensive analog DC motor...I'll estimate the average wholesale cost of this to be somewhere around $10 to $15 US dollars. It would vary greatly, according to quantity buying levels. The only capacitor seen here is barley a by-pass or shunt...I'd prefer to call this a carbon brush protector. As the armature spins in normal operation, the "make" and "break" of the brushes riding against the armature where "flame" occurs...this cap is merely removing or dampening the "spark" and aiding brush-life longevity. At .47 Mfd it's really only helping at the lowest frequencies to roll off the RF spiking, also with long leads, transversing the distance between the two brushes does not help with the higher frequencies of this wild free-running spark-gap transmitter. This is a far cry from the excellent by-passing techniques incorporated into the wimpy little Carter device. Let us take a look at the fix procedure to begin " RF silencing" one of these very substantial LP platforms. We can't be as effective as the fully closed hermetically sealed package but, with careful effort you can knock this "ripple hash" down by 40db or better in just this simple step. The procedure above depicts a simple "drill and tap" technique using small machine thread hardware. 6/32 or 10/32 should suffice. You can use what ever hardware is available in your junk box as long as it is small enough to fit into the limited working space. Purchasing a small tap and companion drill at your local hardware store to match your "screw-thread pitch" is very low in cost. The skill required to do this is modest, just take your time and carefully hand-cut your threads gently. The cast aluminum end-caps are very easy to drill and tap. NO 9% IPA's should be consumed prior to drilling! Keep your hole straight and pay attention to the "depth" of your drill. With the armature removed you can "eye-in" an approximate location for the mounting hole to accommodate the miniature "lug"...this is where you make an accurate decision of the "angle" for the lug's contact arm to avoid contact with a spinning armature in "run-mode". You must also consider component "lead length"...keep this EXTREMELY short...it will be like working on a Swiss watch in confined space. NOTE: You must loctite your threads! This procedure is introducing component count within a very critical area...errors in loose components will be catastrophic !!! You will make NO errors here! Sorry...my photo is fuzzy. The photo below is zoomed-out for examination of component placement within the end-cap structure. It is tight but, it is precise and highly efficient. This depicts component selection: two each .1 Mfd silver Mica 100 volt dipped packages. I happened to have these in my junk box and standard miniature ceramic caps would also suffice. This completes the "critical" internal modification to initially "RF silence" the armature brush contact event point. I buy electronic components/parts from DigiKey or Mouser...these two capacitors will set you back about 30 cents each...your shipping cost will be ten bucks! Boy...I miss those cheesy little Radio Shacks. It was so convenient to buy little things like this for little money within my own community. Times have certainly changed. Now, carefully reassemble your enhanced LP device and mount it into it's operational nest on the vehicle. The photo below is the final step in this procedure. Again, this shunt capacitor is a .1 Mfd Orange drop package rated at 100 volts. I do prefer this package over standard Ceramic disks under the hood within engine compartments due to heat stress. These maintain tolerance over an extremely wide temperature range. The shortest leads possible, again, is the goal...the lead is directly connected to the relay socket where the 12 volts DC is connected through the relay contacts, that when "closed", provides DC excitation to the LP. I could have made these leads shorter but, I utilized the present ground on the firewall for convenience. Insert the relay back into the socket. This now completes the entire procedure. The monetary expenditure amounts to less than $1.00 for the capacitors. The time involved is substantial. The $689.00 plus dollar, advanced LP platforms available should have arrived fully prepared for trouble free installation and operation. The design engineering staff at Dailmer Chrysler would have never introduced an uncontrolled CCS constant run DC motor device into their platforms at any level. Cummins also, would have never allowed a DC pump without qualification standards to be specified for any production platform. The factory OE Lift Pump from Carter is a very under powered volumetric unit and their is no debating that short coming however: electronically it's design is superior in every aspect. The entire hermetically sealed housing acts as a complete Faraday Shield to fully encapsulate all electromagnetic static fields of force. It is a "dead silent" RF void device! This is just an example...all of the after market companies tout their prowess in delivering liquid fuel at astounding levels of performance, be it a stock engine or perhaps an extremely high horse powered competition street killing monster. None of them provide a civilized RF silenced DC motor to prevent "other" electronic automotive control elements from being harmed when operated within the confined structure of the vehicle. Note: not one bit of verbiage regarding the actual DC motor that powers the device! But, it pumps fluid like heck! I so dearly appreciate the flow factors, the filter systems, the mounting structures and comprehensive packages to alleviate all the short comings of my dismal factory transfer pump issues. Knowing well, that I'll never allow my one thousand dollar plus VP44 from ever being fuel starved again, by selecting an aftermarket LP system...only to realize afterwards, that the introduction of this major investment into my vehicle is now causing electronic issues, else where, within the vehicle! The expensive sound systems, vehicle speed sensing systems, erratic operation of TC lock-unlock, cruse control abnormalities, and radio communications equipment. All of these things at one time operated without error, you enjoyed the accurate trouble free aspects of your prized motor vehicle, then...something happened! Being cautious about adding any electronic implement into a trusted vehicle is always prudent. Asking the right questions before hand is always best practice. This information applies to ALL Vehicles regardless of manufacturer Ford, Chevy or Dodge. This article is following additional postings on this web-site...Mike Nelson @Mopar1973Man and Nick @Me78569are struggling to keep this small and independent site operational. I am not affiliated with any supplier or manufacturer...I am a contributing customer who appreciates the time proven and solid information/guidance these two men provide to the diesel community. I humbly share this knowledge with the CTD fraternity with enthusiasm, for the improvement of our platforms...may I ask a very small favor...if you find the information on this site of value could you please consider making a one dollar donation to the site to keep the lights on Thank you, Respectfully, W-T
Ground Reference VP44,ECM,PCM,PDC plus TC lock/unlock
Jeremy, this is a cheap eBay purchase for less than $65 and it comes with ten pairs of dies. You can crimp from 8 gage all the way up to 4/0 gage. It's heavy but, it does a nice symmetric crimp with very positive results. As for connectors...I found my local battery retail facility to have the quality zinc coated connectors for about $2.15 a piece. The copper units are available at most hardware stores but, at nearly twice the price. I measured and cut my cables with extreme precision for appearance and serviceability...I wouldn't expect a shop who prepares cable ends to be as careful as I wished...hence, I did this myself. The end result is excellent and I feel the job was well done. Guys...I must shut down for the evening...I won't be back until Saturday April 28th...thank you and safe travels. Cheers, W-T
Morning trreed, the front radiator/multi-cooling condensers have been shrouded with inexpensive black plastic screen since day one to prevent any insects from plugging the air flow pathways. The "breather" puke bottle was removed and I merly extended the "tube" straight down as an "old fashioned" road-draft tube that were common in 1952. I played with the length of this "tube" as it drafts to the atmosphere when the vehicle is moving forward down the road. The "ventury" effect of the minor blow-by was "tuned" to dispel the "oily fairimones" without excessive deposits accumulating under the hood. It allows for a cleaner environment...because the humor of a diesel has a tendency to vomit all over itself. By doing this, I was able to find the length to complement the dispersal of the oily-mist to a precision lower drivetrain contamination discipline. An occasional wipe down of the front Dana 60 is all that is required. As for under the hood...with the lack of oily-mist contaminating all the surfaces I'm able to wipe the surfaces in the same manner as cleaning a firearm. As for the "nooks and crannies" I use a toothbrush only slightly dampened with a drop of WD-40 to "Swiffer" away dust and excessive accumulations. My insanity is fueled by a cold beer and good music as I doodle under the hood and it certainly makes things nice if I have to remove something during a repair. I've been under the hood for hours and barley get my hands dirty. Thank you...it's all for the appreciation of the mechanical newaunces and it astounds the "under thirty group" when they see an "old guy" with something that doesn't make sense. I never laugh as they approach me at a fuel station after exiting their Prius...it's fun to blow them away with real American muscle. dripley...Thank you...I have six weeks to go and I'm fully retired.
Part 2 I wish to apologize for my absence and attempt to clear some of the stress I may have created. Members @GSP7 and @Dodgeih, my humble and sincere apologies. My thanks to Nick @Me78569, @syndicateshop, @IBMobile, @RipnRam99, @dripley and @JAG1 for filling in the blanks during my absence regarding this lengthy posted subject matter. I'm nearing retirement and I'll be more expedient in the near future. This thread is a focus to remedy the tragic TC Lock/UnLock syndrome and it does tie into the alternator issues bestowed to all 2nd Gen CTD owners. The Godfather @Mopar1973Manis the one who deserves the recognition in this thread. The following photos should suffice in rendering clarity to the "procedures" required to accomplish the the task. Please NOTE: the methods applied are Electronic Engineering standards for high-current demands with ABSOLUTE references to GROUND. The excursions are ONLY for balance (equalization) between two storage batteries in a parallel configuration. This is DONE to allow the Battery Temperature Sensor located on the Main Battery tray (driver side) to be accurate during charge-rate intervals for both batteries. This is accutley important when higher current Alternators are placed into the system. I must emphasize the reasoning: The two batteries are physically separated in distance to accommodate the given engine bay and the Daimler/Chrysler budget to produce the CTD platform. Perfection or "the correct way of doing it" was NEVER a consideration of the manufacturer. I do not wish to continue harping on their oversites...this is what should be done in following the opening portion of this thread. This photo depicts the correct 4 gage conductor directly terminated at the Auxiliary Battery positive terminal. @IBMobile has completed this step and documented his work. This photo documents the "direct" ground from the PCM and fender-ground terminated at the Auxiliary Battery negative terminal. @dripley is very correct in mentioning the "least" amount of connections (splices) should be observed. @IBMobile also accurately documents the "hidden crush-splice" in the wire loom near the PCM where this PCM ground originates. To be a purist, opening this conduit and directly replacing this ground lead with a "clean" 8 gage (or 10 gage) and bringing this directly to the negative terminal would be the best practice. This photo depicts the additional 2/0 Gage lines that "absolutely" strap both storage batteries into compliance of equalization. Again, this excursion (not originally documented in the opening thread) is done for ABSOLUTE integrity between the two storage cells. The "charge" rate from the Alternator supplying the Auxiliary Battery is absolute and mirrored at the Main Battery tray temperature sensor for accuracy. Again, this is most important for those who elected to upgrade the Alternator platform to a higher current device. I would encourage anyone applying this general modification to at least provide, one additional ground strap between the Auxiliary and Main Battery. Do not assume the two 0 gage ground leads to the engine block to provide absolute "ground reference" between the two storage batteries, even, if you remain with the "stock factory" Alternator. The direct 4 gage B+ charge line supplies the Auxiliary Battery first and is in parallel with the Main Battery...the engine block is ground however: for ABSOLUTE ground reference between the two storage cells you should strap an additional ground. The temperature sensor at the Main Battery tray relies on "equalization" between the two cells for sinusoidal charge rates. This photo depicts the Main Battery lines and their perspective terminations. The only excursion here is the replacement of the Starter Motor 2/0 gage supply line. I didn't like the ugly factory line from the front mounting location. This line comes up from the back of the firewall and passes below the PDC box...it certainly cleans up the appearance and provides added accessibility below the VP44 and vacuum/power steering components. Changes like this provide additional serviceability with an artistic flare. This photo depicts the left front fender ground location that terminates at the Main Battery negative terminal. The ugly factory "lug" and sheet metal screw has been replaced with brass components. All connections are below the fender-lip and all paint was removed (Dremel tool grinder) to provide a corrected high-current ground point. Below this connection point are two rather large grounding posts that need attention. The large amount of grounding lines in this corner require some TLC, the method I used provides integrity for DC ground and cleans up the crude slipshod procedure. Besides...mine looks pretty. I should also mention, the brass-to-body connection is treated with conductive grease to eliminate any dissimilar "metal-to-metal" corrosion. @JAG1 has procured the best copper-conductive product available for such purposes and I've not been able to con him out of a few ounces yet. This photo depicts the elected components selected for the heavy current demands in this project. All 2/0 gage line is flexible copper Welding stock...it is very nice to work with and I purchased a modest 12 ton hydraulic "crimper" to apply all zinc-coated connectors as terminations. All shrink-tubing is 3M with internal adhesive for moisture incursion prevention. These beautiful Orion battery connectors provide a very convenient sevicability aspect. Please NOTE the Grid Connection point. Removing the protective caps to expose the connector is very easy ! This is done with Mike @Mopar1973Man in mind to allow the Grids to be disabled for the summer time conditions where Grids are not required. A small Allen wrench is all that is required and can be performed in less than one minute.This photo depicts the graceful run of four 2/0 gage lines across the top of the radiator and artfully draping into position.This depicts a correct Parallel DC storage Battery system created with serviceability in mind.This completes the creation of a DC Power supply worthy of the Cummins platform. The new DC Power Engineering XP270 Alternator with corrected DC ground lines and complementary strapping is exemplary. The performance of a cold morning start was impressive as the Grids fired sequentially without a hint of stress. The "stiff" DC current supplied by the XP270 mimicked a full military hardened assault vehicle under load. I couldn't be more pleased The test drive under warm road conditions yesterday afternoon with particular attention to speed and road conditions showed NO TC lock/unlock syndrome...again win/win. I conclude this saga in humble reverence of the Cummins Turbo Diesel Fraternity in a sharing gesture for all disciples. Cheers, W-T
@Marcus2000monsterThanks, and the alternator is a DC Power Engineering XP 270. You'll be able to find them on the web and they are located in Riverside, California. It is a 6 phase large frame unit that produces 200 Amps at idle and NO serpentine belt change is required. I referred to this device in the High Amp alternator thread. It is basically, a drop in platform however; to utilize the potential of this massive component you must consider a "new B+ charge line". This thread address that issue specifically because, the original #6 gage that is encapsulated in the factory 1 inch plastic conduit located in front of the engine would never survive a charge command from the PCM. The original #6 that directly feeds the PDC and passes through the 140 Amp fuse (which is entirely unnecessary) is fully removed. This is done specifically for three reasons. #1: A #6 gage B+ line is not adequate to pass 200+ Amps (the XP 270 will produce 305 Amps peak), furthermore, a high-current line in close proximity to sensitive 5 volt logic sensor lines should never have been produced in this manor. Daimler/Chrysler made this error in production of these vehicles over twenty years ago. Poor performing alternators that developed AC ripple, due to several factors, would permeate the surrounding conductive wires within the harness and render undesired electronic phophas throughout the entire vehicle. #2 The "strange" #6 gage Blk/Tan ground, that is "supposed to provide" critical "reference ground" for the VP and the ECM is directly parallel with this B+ line and in an unfortunate happenstance became a "balanced" pair of "wires" that created a "tuned inductive/capacitive" transmission line to efficiently transport this minor AC ripple with deadly efficiency. This #6 gage Blk/Tan (reference ground) is brought to ground directly as documented in this thread. #3 It definitely cleans up the engine bay with a touch of technical excellence...it is a win-win endeavor for the 2nd Gen Cummins enthusiast May I add...the Factory original #6 gage B+ line providing as much as 135 Amps during cyclic periods of the "grid heater" event, was NEVER ADEQUATE to conduct that level of current ! Take a moment to examine the factory #6 gage B+ line???.. It's stiff...it's cheap... it's cooked...it is a complete act of buffoonery on behalf of Chryslers Engineering Staff to have produced this level of electronic mediocrity . WARNING: for those of you who have elected to upgrade your system with any platform (alternator) that produce 180 Amps...you too must consider an alternative to this woefully inadequate #6 gage B+ charge line. If it melts down within the Factory conduit...you will lose your ECM..your VP44 and your PCM. With great respect to the Cummins Fraternity...I humbly share this information for the betterment of our rigs. Cheers, W-T
This aspect has been fully documented in the "High Amp alternator" thread along with "what" to do for correction. It was Mike's @Mopar1973Man work that called my attention to this long running saga and I only wish to contribute to his outstanding achievement. @Timbo endorses Mike's conclusion and the discussions on countless websites reveal an over-all acknowledgement that the "fix" is fully understandable. A big thanks to Mike Nelson for his accurate diligence in finding the answer!
@GSP7yes...the photos are of my truck and it is a 2001 auto. The "mess" of the "grounding" is strictly what Daimler/Chrysler produced during production. I was merely bringing this to attention because it doesn't follow protocol of standards in regard to DC ground. The examples depicted are what should be done to correct the oversight. I apologize for any confusion but, this thread ties in with the "High Amp alternator" thread which does add to the continuity of the electronic aspects. You're correct, the #8 gage Blk/Tan is a critical ground and the routing Daimler/Chrysler selected is contrary to any standards in Electronic Engineering basics. The result of correcting this will lead to the integrity of DC ground reference for the VP and all associated electronic management devices. The benefits eliminate the proclivity of AC ripple causing error within several related electronic devices which results in unwanted operation. It also enhances the appearance of the engine bay.
After 18 years of interesting CTD enthusiasts and transmission specialty outlets all contributing their method, or fix, to the well known TC lock unlock syndrome, I can no longer remain silent. Extensive review of many posts regarding TC lock unlock, the rerouting methodes, the add on filters for APPS and last, but not least,...the "tin-foil hat" brigade. I do realize that each individual or company that contributed to the vast amount of information on the web had good intentions and I must acknowledge that some of the procedures caused me to closely examine what these people were trying to do. I believe it is well known that even a blind mouse occasionally finds a morsel of cheese. Again, as it is well known @Mopar1973Man was the only entity who positively identified the instigating source of this key issue. My entry today is not about alternators...it is about what Daimler/Chrysler did in regard to production of these Cummins powered platforms and the complete disregard of common sense Electronic Engineering. Please note, this applies to automatic and manual transmissions as each platform is plagued in the same manor with different quirks. This Blk/Tan #8 gage wire is quite critical in the scheme of things. It is contained within a 1" plastic conduit passing along the front of the engine. It contains water temp sensor leads, air conditioning leads, alternator/PCM leads and the #6 gage alternator charge line to the PDC. This #8 gage Blk/Tan passes over the top/backend of the alternator and is "eventually" connected to the Auxiliary Battery (passenger side) negative terminal. This snapshot of the Factory Service manual documents "four critical ground leads" that are "spliced" in an unconventional method. This photo depicts the three #18 gage wires and the single #14 gage wire entering the shrink-tubing where the "crush-splice" occurs. This bundle exits the large plastic conduit below the VP44 This again is a most disturbing depiction of the Daimler/Chrysler method of splicing critical ground leads and then routing this across the top of the alternator and "eventually" bringing this to ground reference. This photo depicts where this #8 gage Blk/Tan first connects on the way to "eventual" ground...yes this is the Auxiliary Battery tray connector. Please note: it is spliced again and joins the PCM circuit board grounds...which are critical in their own nature...and "eventually" terminate at the negative post of the Auxiliary Battery's negative terminal. This photo is very interesting, it is the Factory Service manual and the assembly line documentation follows this as a road map in the matrix during production. Please NOTE the title "NAME" to each battery...I looked at this for a considerable amount of time before I realized the assembly line coordinators tried to work with the documentation from the Engineering Staff to "make it as it looks"...Could this single oversight be the reason of a four foot ten inch critical ground wire combination traveling the distance to "EVENTUALLY" terminate at ground? From a basic engineering standpoint regarding ground...you "NEVER CHOOSE THE PATH OF EVENTUAL GROUND" !!! It is to be the shortest and most concise connection in reference to ground...this is biblical in ALL ELECTRONICS...including pickup trucks. ! Here is the Factory Service manual documenting the PCM circuit board reference ground starting as a pair of #14 gage wires being spliced into a #10 gage bundle and arriving at the Auxiliary Battery through another connector that joins a #8 gage wire that is "splice-joined" under plastic conduit in a Y configuration joining the rouge #8 gage "after passing over the alternator" traversing the entire engine compartment from the driver side of the vehicle. Seriously I have been drinking excessively, most recently, due to the nature of this blatant discovery. This is the hidden Y splice at the Auxiliary Battery where the "mess" EVENTUALLY terminates for ground reference. This photo shows the correct "HOLE" of where to apply ground for the VP44, ECM and the PDC...note the logical location It took a little research to find the size and proper thread-pitch. Metric M5 with a 5/16" hex head is perfect This is where you apply a fresh "quality" #6 gage ground and terminate this at the Main Battery negative post on the drivers side for absolute ground reference for the VP44 and ECM This is a very short and concise reference to ground. This is the corrected procedure for a rather critical ground. The two largest wires originally contained within the 1 inch conduit are no longer present and located well away from the alternator. My alternator B+ "charge" line is now a #4 gage line directly connected to the Auxiliary Battery and when my new battery terminals arrive and they are secured, I'll provide photos of a completed Master Power Supply System within this engine bay. With these corrections, I would hypothesize that a poor ripple specification on a given alternator would be overcome by the immense capacitance of the parallel batteries and would become less prone to causing the dreaded TC lock/unlock for automatics and cruise-control abnormalities for the manual transmission platforms. The #8 gage Blk/Tan passing over the alternator as an "EVENTUAL" ground is gone...the PCM, ECM, VP44 and the PDC are now grounded in accordance of standard Electronic Engineering practices. Respectfully W-T
- 1 review
- 35
Electrical Article - Ground Reference VP44,ECM,PCM,PDC plus TC lock/unlock
After 18 years of interesting CTD enthusiasts and transmission specialty outlets all contributing their method, or fix, to the well known TC lock unlock syndrome, I can no longer remain silent. Extensive review of many posts regarding TC lock unlock, the rerouting methodes, the add on filters for APPS and last, but not least,...the "tin-foil hat" brigade. I do realize that each individual or company that contributed to the vast amount of information on the web had good intentions and I must acknowledge that some of the procedures caused me to closely examine what these people were trying to do. I believe it is well known that even a blind mouse occasionally finds a morsel of cheese. Again, as it is well known @Mopar1973Man was the only entity who positively identified the instigating source of this key issue. My entry today is not about alternators...it is about what Daimler/Chrysler did in regard to production of these Cummins powered platforms and the complete disregard of common sense Electronic Engineering. Please note, this applies to automatic and manual transmissions as each platform is plagued in the same manor with different quirks. This Blk/Tan #8 gage wire is quite critical in the scheme of things. It is contained within a 1" plastic conduit passing along the front of the engine. It contains water temp sensor leads, air conditioning leads, alternator/PCM leads and the #6 gage alternator charge line to the PDC. This #8 gage Blk/Tan passes over the top/backend of the alternator and is "eventually" connected to the Auxiliary Battery (passenger side) negative terminal. This snapshot of the Factory Service manual documents "four critical ground leads" that are "spliced" in an unconventional method. This photo depicts the three #18 gage wires and the single #14 gage wire entering the shrink-tubing where the "crush-splice" occurs. This bundle exits the large plastic conduit below the VP44 This again is a most disturbing depiction of the Daimler/Chrysler method of splicing critical ground leads and then routing this across the top of the alternator and "eventually" bringing this to ground reference. This photo depicts where this #8 gage Blk/Tan first connects on the way to "eventual" ground...yes this is the Auxiliary Battery tray connector. Please note: it is spliced again and joins the PCM circuit board grounds...which are critical in their own nature...and "eventually" terminate at the negative post of the Auxiliary Battery's negative terminal. This photo is very interesting, it is the Factory Service manual and the assembly line documentation follows this as a road map in the matrix during production. Please NOTE the title "NAME" to each battery...I looked at this for a considerable amount of time before I realized the assembly line coordinators tried to work with the documentation from the Engineering Staff to "make it as it looks"...Could this single oversight be the reason of a four foot ten inch critical ground wire combination traveling the distance to "EVENTUALLY" terminate at ground? From a basic engineering standpoint regarding ground...you "NEVER CHOOSE THE PATH OF EVENTUAL GROUND" !!! It is to be the shortest and most concise connection in reference to ground...this is biblical in ALL ELECTRONICS...including pickup trucks. ! Here is the Factory Service manual documenting the PCM circuit board reference ground starting as a pair of #14 gage wires being spliced into a #10 gage bundle and arriving at the Auxiliary Battery through another connector that joins a #8 gage wire that is "splice-joined" under plastic conduit in a Y configuration joining the rouge #8 gage "after passing over the alternator" traversing the entire engine compartment from the driver side of the vehicle. Seriously I have been drinking excessively, most recently, due to the nature of this blatant discovery. This is the hidden Y splice at the Auxiliary Battery where the "mess" EVENTUALLY terminates for ground reference. This photo shows the correct "HOLE" of where to apply ground for the VP44, ECM and the PDC...note the logical location It took a little research to find the size and proper thread-pitch. Metric M5 with a 5/16" hex head is perfect This is where you apply a fresh "quality" #6 gage ground and terminate this at the Main Battery negative post on the drivers side for absolute ground reference for the VP44 and ECM This is a very short and concise reference to ground. This is the corrected procedure for a rather critical ground. The two largest wires originally contained within the 1 inch conduit are no longer present and located well away from the alternator. My alternator B+ "charge" line is now a #4 gage line directly connected to the Auxiliary Battery and when my new battery terminals arrive and they are secured, I'll provide photos of a completed Master Power Supply System within this engine bay. With these corrections, I would hypothesize that a poor ripple specification on a given alternator would be overcome by the immense capacitance of the parallel batteries and would become less prone to causing the dreaded TC lock/unlock for automatics and cruise-control abnormalities for the manual transmission platforms. The #8 gage Blk/Tan passing over the alternator as an "EVENTUAL" ground is gone...the PCM, ECM, VP44 and the PDC are now grounded in accordance of standard Electronic Engineering practices. Respectfully W-T View full Cummins article
47RE Torque Converter Lockup Adjustment
Very well...I believe you'll find excellent answers for this subject matter on this site. @Mopar1973Manhas posted a comprehensive test that directly answers this question. Take a look at 47RE Torque Converter Lock and Unlock post. I believe you'll find this very valuable information in the archive Articles. Take a look and provide feedback on this thread...I would be curious regarding your impression and observation.
I'm sorry...a little clarification would help further in understanding what you're experiencing...when you are just driving along in 3rd gear are you experiencing this "lock,unlock and lock" syndrome? Is this experience occurring often or on a regular basis in your opinion?
New member..frustrated..abs/brake light
Your Question: Correct this issue prior to any other troubleshooting.
ECM Install
The two solenoids are "hot" with DC at all times. The "turn-on" or "activate" is the low current command from the ECU (the small wires at the base of the solenoids). Your test is indeed revealing that your solenoids are being supplied 12 volts directly from the drivers-side battery. Take a look at the two black wires (fusible links) connecting to the positive terminal of the drivers-side battery. This is the connection point that you are reading at the "caps" of your solenoids. This is normal unless you deactivate your grids by disconnecting the fusible-links at the battery post. (Sorry...I don't believe you needed to replace these solenoids) The "short" that Auto Computer Specialists are advising you of is a mystery? Did they inform you of "what circuit" they were specifically referring to? The ECM is all low voltage, low current signal lines and I would think they might have a good idea of "what" circuit was damaged by this external "short"...if they examined your ECM that you provided as a "core" they would be able to advise you of where to look. The master connector at the ECM is daunting and the signal paths are quite wide in scope...I would call and ask them these specific questions. It is very good that you have NOT powered up your system at this time. They have received funds from you to obtain this rebuilt ECM...you truly must find the person who reviewed your core ECM on arrival. I believe it is "they" who have advised you of this "unknown short"...ok...now, make them tell you what circuit was damaged.
ECM
The ECM and PCM connectors should be dressed with this product. Any multi-pin connector with delicate access should be messaged with this product prior to reassembly. Any "weather-boot" style connector should be gently cleaned and then with a Q-tip gently swab your boots with Electronic Silicon grease prior to "squishing" the mated pair back together.
Lift Pump Question
@Mopar1973Man these 5G aspects should be removed...I'm sorry for the mess...I just piled on incorrectly
Lift Pump Question
Gosh..my apologies for my flippant response...this thread has become a bit off focus...none the less. @Dieselfuturethe advancement of Cellular has progressed at an alarming rate. Everyone has a phone and the frequencies being utilized for this service are in the lower end of the microwave portion of the frequency spectrum. This portion of the spectrum officially begins at 1 GHz and I believe Cellular occupies segments in the 2.4 GHz slot. The exact location is not necessary for this discussion, it's just best to know you're holding a microwave transceiver, operating in full duplex to your cranium. Madam Marie Curie maybe the most recognizable French/Polish physicist to have brought attention to radiation and awoke the world to "what you can not see might very well harm the human body" announcement. Yes...she payed dearly with her life for the experiments she conducted. Bless her soul. Today's modern world affords all of us with fabulous technology and with common sense application,... we all benefit. These small radios (cellular devices) do operate at frequency octaves that can or could cause heat damage to the brain and sensitive optic nerves of the human body. A common chicken egg in the kitchen micro-wave oven will display a fine example of the effects of concentrated micro-wave energy. The "power" of a common micro-wave oven is way more powerful than a cellular phone. These cellular phones operate at very low levels of RF power output and exposure to these levels are what the EPA and FCC refer to as none harmful when used reasonably. I guess if one was to talk on the phone non-stop for ten years 24 hours a day you might expect to have some side effects. The first thing someone would notice is your cornea of the eye would begin to "milk-over" much like cooking an egg. To lessen long term exposure, use your phone less...and remember this: When the signal on your phone indicates maximum signal strength from the near-by cell tower installations the ALC (automatic level control) of the transmitter portion is regulated by the relative field strength of the "received signal". This means that when you have a great signal your transmitter is operating at the "lowest" RF power output because it doesn't need the power to hit the cell tower. This means your battery power lasts longer for that long winded conversation. You will have more "talk time" in a strong signal environment. If you note your signal strength indicator is low...your ALC circuit will increase the transmitted power to maximum levels and that increases your exposure to RF radiation levels. Weak signal environments or location will tax your battery supply much quicker. Chatting on the cell phone with maximum received signal strength will lessen your RF exposure. @notlimahwould have direct knowledge of these principles at micro-wave levels. How did we get to RF, micro-wave and ALC from a "lift-pump question"...it's too early for a beer yet...so Dripley...you're the lead man here for additional libations after 5pm.
Lift Pump Question
Guys...I'm so loaded...I'm just trying to catch up with Dripley...something about muffler bearings or battery bushings...oh heck...
Lift Pump Question
I've caused too much derailment on this thread...notlimah...I knew you had a background in radio frequency and no, an extra length of wire is not at issue. I caused this confusion please allow me to complete the presentation in a subsequent thread. RADAR...wow...I love Klystrons and TWT (traveling wave tubes) let's trash the site in a different thread...I'd be most interested in your skill set. I'm drinking a beer The "twist" method is surprisingly still being used in many production runs not only to "reject" an interfering signal but, also for self containment. This is very common in high current AC lines within chassis design or distribution runs. It also has merit with low voltage low current DC lines as well. I'm going to go get some chips to go with this beer. Cheers
Lift Pump Question
I'm just retrieving my photos for the Carter pump...I saved these years ago and I'm stumbling trying to find them. A picture is worth a thousand words. True, any coil of wire will have electromagnetic properties when excited or charged but, in design aspects these properties can be controlled or entirely eliminated if the following circuit has a proclivity of error due to the collapsing of an electromagnetic field (EMF). This device you're referring to is most likely well engineered and these extension arms being followed by coiled electrical cables, most likely, are well thought out. An error at that level is huge and would not escape into the field of operation. I am not an electrical engineer, I do hold a First Class Radio Telephone License and I've been practicing the study of electronics for 50 years. I consider myself a tenacious technician...I have contributed technical writings for electronic review magazines and though not 'American Scientific' I have been honored to be in print. I have no academic pedigree...I'm just a poor kid from Butte, Montana that learned to read and to utilize my meager knowledge at a weaponized level of proficiency. Yet...I'd rather drink a beer and make people laugh.
Lift Pump Question
Interesting aspect to NOTE in this subject...without knowing what circuit the Engineer was eluding to... it would be difficult to take a guess. Yes, there are systems where the I^R losses are important to maintain, regarding sensors for telemetry. Being that this 480 volt 3Phase system is a large scale device, there may very well be merit in what the Engineer stated to the Install Technician. Our situation is slightly different regarding noise generation (RF) with undesired responses from TC lock/unlock and cruse-control idiosyncrasies. @Marcus2000monster The Carter pump did have some excellent design aspects but, the diesel community realized the short comings and the cost of NOT paying attention to how feeble this pump was in our environment...allow me the latitude and I'll spill the beans on this device. BTW..guys...I do not wish to come in and side-track a thread...occasionally my enthusiasm for key elements within a running thread causes me to overlook the focus. My apologies
