Seat belt light
There are two wires that run into the buckle on my truck. I had the same issue as you, one of the wires broke from years of flexing. I grabbed another buckle from the salvage yard and that fixed it for a few years but it’s happening again. I may have to try repairing it this time.
Sycostang67 started following Do I need to bleed fuel system again? , Seat belt light , Understanding stock Quadzilla and 4 others
TJ at 1badvp44 does good work. I had him write me a street tune just before my quad and ecm committed suicide. The truck ran much better than with any tune I had written.
WOLFBOX G850 PRO 4K Mirror Dash Cam
I have a dash cam in the truck but I don’t have it up right now, I can’t remember why. The truck sat so long with the ecm dead I forgot about it. The one I have in the mustang is pretty nice though, it’s small and hides behind the mirror. I also found a harness that plugs into the wiring for the rear view mirror so I didn’t have to run any wires through the car.
I think I finally have this fixed. My fuel pressure had been getting very low a few times, 0-5psi. I just replaced all the fuel lines and swapped in a different check ball and spring. The old ball was definitely stuck in the spring, they did not separate as easily as they should have. Fuel pressure is now sitting steady at 13-14psi.
Beast - 500k miles - Projects
Good grief, that’s a heck of a to-do list. I was using a pop up canopy to keep the sun off my back while my truck was down. Could save you from some rain if you can’t get in your shop.
Front driver's seat removal
I think you remove that side trim piece, but slide the seat back and get the two rear bolts and then forward to get the front two. Getting it back on and lined up can be a little tricky but certainly not difficult.
If you only need to remove the padding, I know the bottom part can be removed with the seat in the truck. I’ve done it twice, once to replace the foam and again to install a seat heater.
Electric vacuum pump
How did you deal with the old vacuum and steering pumps?
Yeah, those are the ones. I’d really like to replace all my fuel lines as the blue stuff that came with the FASS looks like crap. I’m broke as hell right now though so it will have to wait. I will take a better look at the fittings though, I was supposed to the other day but had so much other stuff going on at the same time I totally forgot.
I have the metal push lock fittings. I didn’t see anything wet, but it has gotten better. It’s still not as good as it used to be but is starting and building pressure better.
I need to change the oil this weekend so I’ll crawl around underneath and see if I notice anything.
My sensor is mounted on the pump, but I imagine the line would still have to fill before any pressure was created. I do have a sensor closer to the VP but that had the Quad plugged into it which is no longer with us.
When I started my truck the first time with the new ECM the fuel pressure was at its normal range of 14-15psi. After I shut the truck off I replaced a wire on my switch box and accidentally knocked a wire from the fuel pump relay. When I started it again I noticed I had zero pressure. Thinking I could figure it out quickly, the truck ran out of fuel. Once it was sorted the truck obviously wouldn’t start. I loosened the fass filter and ran the pump until it gushed and then retightened. I then cracked 2 injectors and cranked until they bubbled out fuel. The truck runs but now it takes a a few extra seconds of cranking when cold to start and the fuel pressure gauge doesn’t read until a few seconds after it has started. My pressure is now at 18-19psi. The truck runs and drives fine, not sure what to do.
Flashing WTS light
Mike if you lived closer I would kiss you. I had to remove the t-case boot to replace some wires and left it in neutral. 🤦♂️
Flashing WTS light
Apparently this trip isn’t over. The truck runs but now it doesn’t move. When I put it in gear the rpms drop a bit but no movement. When I try to put it back in park it grinds. I have to shut truck off to get back in park.
