- Replies 13
- Views 2.3k
Threadzy 6 posts
Mace 3 posts
Sycostang67 1 post
Stanley 1 post
You are right about the retractor having the switch in it. From the FSM: "A seat belt switch is integral to the driver side front seat belt retractor unit."
Well I think I’ll remove it and see if I can find a similar one from maybe a later model Ram and see if I can make it work. If I do I’ll post which one I used. Yes, it’s held on with 1 screw, easy. T
Wrapped the CMT today. Tomorrow morning will be the test.
I’ve been killing some gremlins in my truck lately and this is the last one.
I’ve had the 3 horn honk when unlocking the door with my fob for the last 15 years that I solved by wrapping the ctm in foil tape…this blows my mind. $6 from Home Depot. Unbelievable.
The last is my driver side seatbelt latch switch is i think the issue. The dash light stays on but if I wiggle the latch just right it stays off. I think the switch contacts inside is worn out. Has anyone found a seatbelt latch that’ll work (they’re discontinued) or is the switch serviceable?
Edited by Mace
