Tractorman
  1. @Doubletrouble, I received and installed my cup holder. It works well with my 6 spd. I think the truck has just a little more power now, too. At this point, I didn't use any hardware to fasten the cup holder. I did notice that the console lid doesn't latch anymore with the added material of the cup holder. Did you have the same issue? - John
  2. Something else you may be interested in..., After dropping my fuel tank twice over the last 20 years, I decided to make an access door through the truck bed. One of the best mods I ever did. The actual time it takes to do the mod is about the same as dropping the fuel tank, replacing the basket, and re-installing the fuel tank. With the modification completed, I can now remove the fuel basket in about 10 minutes. Easy access to electrical and fuel connections, easy to remove the large threaded nut, easy to remove and install the fuel basket. Also, the job can be done regardless of the level of fuel in the tank. - John
  3. There is another option without modifying your new fuel basket plumbing. On my truck with an OEM fuel sender basket (no pump), I installed the basket and hooked up the fuel lines in an OEM fashion. Along the frame I cut the return fuel line and installed a three-way valve and added a fuel line and a tee to the fuel tank filler neck. With the newly added three-way valve in one position, fuel returns to the basket - a good option during winter months when warm fuel is desirable. With the valve in the other position, fuel returns to the fuel tank via the tank filler neck. This is a good option during the hot summer when cooler fuel is desirable. Just be aware that whichever method you use, more fuel will flow through the one-way check valve in the bottom of the fuel basket when the fuel is returned outside of the basket. This will result in running out of fuel sooner as the fuel tank nears empty. When fuel is returned directly to the basket (about 70% of the volume drawn from the basket), then the fuel level can be drawn down a little farther before running out of fuel. Here is the filler neck T. - John
  4. Thanks for the photos and the followup. I think I'm going to do it Is this the correct cup holder? - John
  5. I am curious to hear back after you drive the truck using the cup holder. I may have to do the same mod. - John
  6. I have a Smarty S03 and the high idle is enabled on my truck. I was not impressed with it at all. First, there are many times I wished the high idle would come on in the 6 cyl mode, but it never did. Then, when it did operate, it ramped up to the 6 cyl high idle and then switched to the 3 cyl high idle. OBNOXIOUS!! HORRIBLE!! The first time it activated, I was in the house. I thought the oil drain plug must have fallen out and all the rods were knocking. Not for me. These trucks are already noisy enough - especially when they are cold. So, last summer I decided to install my own mechanical high idle. It works very well and I get to be the boss and turn it on whenever I want. It is also nice to have on a 100° day in a parking lot. I posted what I did on this site. Here's a link. - John
  7. For the second generation Dodge Ram ('95-'02), this is about the blend door actuator. It is the only electronically operated ventilation door on our trucks. The rest of the doors are vacuum operated. The blend door's OEM "interposer" is plastic and prone to cracking or just wearing out. The replacement interposer is steel. - John
  8. I wrote this post almost 24 hours ago, but an ice storm nearby shut off the internet service, so I could not post. Even though it appears that you have solved your problem, I am posting now anyway. I would use a test light with an incandescent bulb for all my tests. This test light will place a small electrical load on the circuit being tested and clearly show whether or not the circuit is working properly. The tests are simple and reliable. For part of the testing I would use a jumper wire. For the following tests, use the wiring diagram to follow along for each test to help you understand the test and the test results. Make sure the transmission is in "Park" and the park brake is set. Ignition key "Off". First test. This test will check continuity between the starter relay terminal #87 and the starter solenoid. Remove the starter relay. Use a jumper wire and connect one end to terminal #87 of the relay base and the other end to the positive battery post. The starter should operate. If it doe not, then continuity between terminal #87 and the starter relay has been lost. Second test. This test will check continuity between the starter relay and ground via the transmission neutral safety switch. Connect a test light clamp to the the positive battery post. Touch the other end to the #85 terminal of the relay base. The lamp should glow. If the lamp does not glow, then have a helper move the transmission selector around during the test. If the lamp occasionally glows, then the transmission linkage needs adjustment or the neutral safety switch needs be replaced. Third test. The test will check continuity between the battery, through Fuse #9 (30 amp), and terminal #30 in the relay base. Use a jumper wire and connect one end to terminal #30 and the other end to terminal #87 in the relay base. The starter should operate. If it does not, then check the condition of the 30 amp fuse and wiring between terminal #30 and the battery. Fourth and last test. This test will check continuity between terminal #85 and the ignition switch "start" terminal. Connect a test light clamp to the negative battery post. Touch the other end to terminal #86 in the relay base. Have a helper turn the ignition switch to the "start " position. The test lamp should glow. If it does not, then continuity has been lost between terminal #85 and the start terminal on the ignition switch. Performing these tests should find the problem. - John
  9. I think @IBMobilehas it right. When the coil is energized, current will flow between terminal 30 and 87. - John
  10. Your readings could very well be correct. Heating elements can fail both ways - a shorted / partially shorted circuit or an open / partially open circuit. Either way, there will be little or no heat generated by the element. I would be curious for you to retest the old grid heater elements on the bench to verify your first test. Also, do you make a practice of setting a specific range on your multimeter? Do you first touch the leads together to ensure a "0" ohm reading with the leads before testing a component? Even if you checked the resistance value for an new one, the information would not be helpful. Using Ohm's Law one can calculate the approximate resistance value, but only for a heated element that is probably glowing. Under a load the applied voltage would be around 11 volts. The current flow would be approximately 90 amps. That would calculate to be around 1.22 ohms of resistance. But, since that is a heated resistance, that resistance value doesn't mean much. The resistance value would be much, much lower after the element cooled. Our meters do not have anywhere close to the capability to read accurate resistance values that low. Even if they could, an absolutely perfect electrical connection would be required at both meter connections and the resistance value for a cold element would have to be known. Another way to look at this would be to consider that only one wire strand of a 20 strand wire was connected and the rest of the wire strands were broken and not connected. The one connected strand would still give you the same almost "0" ohm reading, consequently, there would be no value to that reading. With one connected strand and 19 disconnected strands, an electrical load could not function properly, yet the ohm reading would indicate that the circuit is okay. - John
  11. Today's weather forecast was to be partly sunny. No mention of snow. But we got 4 inches anyway. - John
  12. Make sure to verify that the ground terminal of the grid heaters is not problem before replacing the grid heaters. Probably not the case, but it shouldn't be overlooked. - John
  13. @Doubletrouble, I apologize for my remark regarding not being ready for winter. It was meant as humor, but obviously it didn't come across that way. I know that you have some hardships come your way and it seems that you dedicating yourself to taking care of your parents. Very caring. You don't need any sarcastic remarks from me. Also, I thought I was quoting MoparMan - he lives in snow country. In fact, he is about 90 air miles to the east from me (across the Snake River). I think I should pay more attention to who I am quoting. - John
  14. It's January..., How could you not be ready for it? There's more coming your way - looks like a snowy week ahead for us. - John
  15. I can't offer any help regarding the transfer case, but i do have some thoughts about lack of traction in two-wheel drive. * What tire pressure are you running in the rear tires (looks like a dually according to your avatar)? I would run no higher than 40 psi, maybe even less. * Throw some weight in the bed over the rear axle. (500-700 lbs). I carry a 600 lb pallet of pavers during the winter month just for that reason. It works very well for traction, even in two-wheel drive with an open differential. * What material is the clutch made from? organic, ceramic, etc? Organic will have the smoothest engagement Ceramic encourages axle wrap. * What is the condition of your rear shocks? The rear shocks are mounted at an angle on the rear axle to help with forward / reverse torsional stability when putting power to the wheels or engaging the clutch. * Do you engage the clutch without throttle? As you know, these engine have lots of clutch engagement torque. No throttle should be applied until the clutch is fully engaged. Any or all of the above mentioned items can contribute to wheel hop / axle wrap and / or traction loss. - John
  16. You need stop sharing useless facts! Now! We have no use for useless facts! In case you haven't heard, we are in a global warming trend. This has to be the warmest winter ever! It just has to be! For everyone! Everywhere! Oh no! I just found out it's supposed to snow tonight - that's going to wreck everything. - John
  17. That's a nicely detailed list. You have to feel good completing that job. That transmission and clutch combination will be enjoyable to drive and should take you lots of places trouble free. - John
  18. @dlg , you bring up a lot of good points and I completely understand your frustration. A stock 47RE is not a good transmission to have behind a Cummins 5.9 liter engine. You have listed all of the shortcomings of this application very well. Well, you may or may not, but I am going say probably not. The Cummins engine develops peak torque at about 1600 rpm. It maintains close to peak torque even above 2,000 rpm. If the truck loses road speed in 4th gear locked up climbing a grade, this means that the load has exceeded the full torque capability of the engine. If the converter did unlock you would have the slight benefit of a simulated partial downshift that would provide slightly more torque to the rear wheels, but that added torque would be cancelled immediately by the power loss from heat generation of a slipping torque converter. This means less power to the rear wheels. And, this excessive heat will be damaging to the transmission. So, when your transmission downshifts to 3rd, you have much more torque multiplication to the rear wheels and when the converter locks you will now even have more torque to the rear wheels. The truck will accelerate easily. Another downside to the overdrive gear (4th) on the 47RE is that the gear is too tall. The overdrive gear in the manual 5 and 6 spd transmission is not nearly as tall, thus better aligned with the Cummins engine torque for better performance. No, because the converter will immediately lock up and all of the engine torque will go to the rear wheels Yes. but not as much heat for the same grade. You will have much more available torque because of torque multiplication from the gears as you shift to lower gears. So, not a much engine power is needed. Hopefully that wasn't really a 45 degree hill. That would be 100% grade. A 10% or 15% grade is very steep. Regardless, yes, you would be making lots of heat. It really is not okay, but that is the product you have (the 47RE) and you can't really do anything about that particular situation. The transmission cannot be locked during a shift. If it was locked, the shift would be jarring and damage to the transmission would likely occur. It would be like speed shifting a manual transmission. Most people who have used this transmission for towing have significantly upgraded the transmission - mainly a lower stall speed heavy duty triple disc torque converter (converter lock up clutch), higher line pressure, heavier clutch packs, and converter lockup available in every forward gear. These amenities allow for the use of an engine tuner that will provide the needed engine torque to easily climb grades in fourth gear locked up. Both the engine and transmission will be happy. - John
  19. When would it be hugely beneficial to be not locked up in 4th? An unlocked converter generates heat, lots of heat - the heavier the load and the further the throttle is pressed, the more heat will be generated. When the converter is locked, all of the engine power is transmitted to the rear wheels (just like a in a manual transmission), thus generating far less heat and putting much more power to the wheels. To me the "bad design" is there really should have never been only four gears place behind a high torque at low rpm diesel engine in the first place. And even worse, only the two top gears allow converter lock up. Simply not enough gears (or converter lock up) to keep the engine in the peak torque range. This is why I drive a 6 spd manual transmission - always the right gear available and no slippage, no matter how demanding the load is. Gears one through three are shifted hydraulically. Fourth gear is shifted electrically with a solenoid. Converter lock up will happen only in third or fourth gear. If there is a full gear shift happening, there will be a significant engine rpm change. If the converter is locking and unlocking, there will about 100-200 rpm change under light throttle. See if you can determine which is happening. Sounds to me like a converter unlocking and locking under a steady throttle - and you are right, that should not be happening. The PCM supplies the signal for converter lock up. When unwanted converter unlocking and locking occurs, it is usually an electrical field interference generated from another electrical source. The PCM stores this unwanted information until it determines that is normal and then changes the signal to adapt to the new normal. One thing to try. Disconnect the ground at both batteries. Turn the ignition switch to "run" position. Slowly depress the throttle to the floor and slowly let it return. Do this two or three times. Hookup the batteries and drive the truck. Did the problem disappear? If so, this confirms that you are having an electrical interference with the torque converter lock up signal. The symptoms will return. - John
  20. This is normal operation. This is also normal operation. If the transmission is in fourth gear, pressing the Overdrive button "off" is commanding the transmission to downshift to third. There is no "switch" to unlock the converter. At what speed and which gears? Or is the converter locking and unlocking instead? - John
  21. A most unusual sunset last night. The colors reflected from the sky made the snow turn pink. - John
  22. Your description of the engine power loss indicates the engine is going into "limp mode". The ECM will reduce fueling to a specific level when certain parameters are not met. If you are getting codes pointing to the VP44, this could be the cause of triggering the limp mode. What are all of the codes you are showing? These DTC's are important as they are a good source of information to help diagnose whatever is going on. This could be normal. The engine will not produce much heat while in the limp mode. I drove my truck for one year (over 20,000 miles) with a P0216 code (timing issue) that would force the engine into limp mode on a regular basis. I just learned how to drive the truck to avoid the limp mode until I replaced the VP44. - John
  23. One thing you can do in the interim is to park the truck on a fairly steep incline overnight (nose pointing downhill) and see how the engine starts in the morning. Make sure the fuel tank is at least half full. If it starts easily, I would suspect a leak somewhere between the tank and the injection pump inlet. You may get some differing opinions here, but I don't think this is the source of your problem. Is it possible that you are having a problem with the fuel shutoff solenoid? - John
  24. Couldn't ask for a better start for the day.... Happy Holidays!
  25. What are the actual symptoms that initially brought it to your attention that something was wrong? Was the engine running poorly? Did the engine just not start one day? What happened? Those details may be helpful. Here is a wiring diagram from a 2006 FSM for the injectors. You may already have this diagram, but if not, maybe it will help. The four DTC's you are getting indicate a poor electrical connection somewhere in the circuit. - John
