Marcus2000monster
  1. Alright I’ll try that And I’m gonna reset the apps after work. Anything else? I don’t know if this has anything to do with it but it barely smokes at all which I like but I have talked to several guys and they said they could fill a bus stop on level 6. Maybe that’s because I have stock injectors?
  2. Ok so I tested and got 12.47 volts on the tap wire. Now I noticed this morning on the way to work that it has even less power than yesterday. This is a Hot unlocked Juice on level 6 so it’s really weird. Another thing I mashed it and couldn’t get more tan 20 psi of boost. Also the edge has not boosted my fuel mileage by mire than .2 miles per gallon!!?? What next?
  3. Test the tap end or the end tha goes into the module?
  4. Haha I just got back from a ride! It was only about 3 miles though? Is that sufficient? Still does not have the right amount of power it should with a Hot Juice
  5. Cleared codes and they haven’t cMe back yet.
  6. Thanks Moparman. So I performed the p0237 test and here’s the results... so orange map wire tested positive at 4.96 volts. Disconnected ecm and was not able to get a reading from terminal 2 and ground nor from terminals 2 or 3 on the map harness. I’m stumped now. So I forgot to turn off he ignition when I reconnected ecm and now have the codes p1693 p0237 p1693 p1694 now what? Please help! Thanks Also p0123
  7. In the article on testing this if says you need a dvom something or other? Same as a multimeter?
  8. Reading 12 volts I just thought of something else. It almost seems like the turbo isn’t building good boost I need to do a pull after work and what kind of boost I get but I’m fairly certain it has nothing to do with it Wouldn’t you know it I just threw a P0237 after hooking my stuff back up! Cleared the code and good so far. I’m getting mad at this code! It pops olio almost every time I fiddle with a programmer I have cleared the codes and tested everything but everything seems ok! Ordered a new map from Genos. Let’s hope this fixes my problems from the past. I had similar issues with an edge ez throwing the code and lacking power and now this guy is doing the same. As I said I performed several tests and everything seems fine. If I have bad map would it cause the juice to read lower boost and not fuel all the way?
  9. I’m dumb when it comes to multimeters but what do I put the black wire on ?
  10. I’ll grab a multimeter and check shortly My millimeter probe didn’t fit in in pin receptacle so I can’t tell the volts. Is there a different way to test?
  11. I have a issue with my Juice I think. I’m not to concerned about it because I’m getting rid of the edge and going back for another Qaudzilla. So i went to check my wire tap and promptly lost the posi tap piece. Ordered a new one and reconnected it and seems rather slow compared to the first time I tapped it?? Any ideas? No codes or anything. Almost seems like a dead pedal but not really. Definitely has more power than without wire tap though so I lm sure it’s getting fuel. Fuel pressure is 18 at idle and 13 15 wot.
  12. So I want the Moto control 9007/9004 kit correct?
  13. Ok that works I just want something better than what I got! Have you used the ones in the link?
  14. Right I’ll go over hat again. http://www.amazon.com/Dodge-Pickup-Package-Headlights-Replacement/dp/B0128TUZP0/ref=sr_1_3?ie=UTF8&qid=1458832075&sr=8-3&keywords=55077025AC Are these a good option for housings?
  15. In this article we’re you using sport housings? Does the kit come with parts needed for sport or regular oem housings?
  16. Is there still a large difference from my stock lights with the mini h1s? I have nothin against your kit I just would like to get something cheaper! Lol https://www.theretrofitsource.com/complete-retrofit-kits/bixenon-morimoto-mini-h1-stage-3.html#reviews this is the kit I’m thinking I’ll go with if you guys think it is an alright way to go?
  17. So I have to buy a left hand kit and right hand kit? Or is the price for both sides? With my options I have 300 bucks
  18. How simple is the install? We’re yo happy with them?
  19. https://www.theretrofitsource.com/complete-retrofit-kits/bixenon-morimoto-mini-h1-stage-3.html#.VvQD8vkrL4Z Gow about this? Got his idea from a old thread on he site.
  20. Checked the fuses in the under hood panel and they look good. Will check grounds after work...
  21. I have to buy absolutely nothing else? That’s cool cause most of the time you have to buy all kinds of other parts! ;) So with mnoptions selected income up with 575 bucks! I selected the h1 option. Is there something else I’m missing?
  22. So is that everything I need or do I need the morimoto light kit then?
  23. Ok I know right where your talking about now! Thanks
  24. Well I may consider that! The other reason. For not doing hids is because the cf guys told me not to do them! So you are happy with yours? Where did you get your housings?
