Marcus2000monster
  1. Yea so I could get the harness and britebox from genos and the rest from dap? I would love to make my own but I know nothin about wiring! Lol https://dieselautopower.com/standard-to-sport-edition-headlight-conversion-9402spchl/ This is the correct kit? I would like the britebox to. Is thier a benefit to getting the harness with relays? Here is the link for the britebox harness https://www.genosgarage.com/product/bb-4-2-7-4bflcu/accessories-lighting
  2. Hey guys sorry to bring this up again! I have searched and haven’t found answers to my questions! So I would like to upgrade my stock headlights. I have ruled out hids because of price and all. I think I would like to do the sport light upgrade. I need someone to post a link to lights they have bought and love!! I’m looking for smoked stockbstyle headlights but don’t have to have them. Now my question is if I do this swap is it completely plug and play? If inget a Geno,s Britebox is this goin to work well with this setup? Thanks guys!! I found a sport wiring harness and britebox together at Genos has anyone used this ? Is it good quality? If I get that all I will need is housings and bulbs correct?
  3. Sorry to be in the dark but do you mean the the fuse panel inside the dash behind the drivers door when you say kick panel? Are the grounds actually inside there? Sorry I’m an idiot when it comes to electrical! ;)
  4. Hi all!! My headlights are extremely dim in high and lows! If I didn’t have a light bar I would have already been in the ditch probably! Lol not quite that bad but they are definitely abnormally dim! What should I check test etc ? Thanks
  5. Ok I figured to problably should do it before...
  6. It was slow on my computer too... my cell works fine though... this guy claims there is no evidence and is strictly against it but he has never tried it and he claims he has 1.3 million miles on one single vp! Lol not only that’s but he also claims to have 400k on stock injectors! Waiting till my next fuel up to add the oil... or is it ok to throw it in after the fuel?
  7. I posted this same topic on cf and some guy is loudly proclai ing against it! Lol ;)
  8. I can’t really see it clearly but it looks clean! Picked up some super tech tcw3 at Wally World last night! ;)
  9. Thanks for the input! I think I will try it on the next tank!
  10. I have read tid bits about putting 2 stroke oil in diesel fuel. What are the benefits? Lubricity? Fuel mpg? How much do you put in a 34 gallon tank? Is there a special type? Thanks!
  11. It’s the code that had a few weeks ago that I never cleared... i honestly think that it is directly related to the edge ez. But then again just to see what would happen I unplugged the map and turned the ignition on and got the p0237 again. It only throws it when I unplugged the map... cleared the code and a ok as of now. Please bear with me here while I work with this.
  12. Ok got the scanner and scanned and got a same ok po237 cleated it and were good to go... so I guess we are all good
  13. Alrighty! I guess I’m going to try the Juice after all and sell it if I domt like it! Running the tests tonight with scanner and multimeter befor ordering...
  14. CN I do the same with a JWA?
  15. Alright thanks guys! And the truck is a 2000 so I’m assuming the p1693 is a companion code and I have more that my scanner will read which is arriving this afternoon...
  16. Got it so I’ll check for more codes as soon as my code scanner gets here this afternoon
  17. I didnunhook hem last night to do the apps reset would that have anything to do with it? Kinda hijacking my own thread. But I just heard bout the key trick for checking codes and I got a p1693 code!
  18. I went out this morning to start my truck for work and she fired right away but now the idle is way worse. It will idle fine and then bog down a little bit for like 2 or three seconds and then idle fine again. As I said yesterday scannernis coming this afternoon and I’ll be checking for codes. Any more suggestions?
  19. Gotcha... tonight I did an apps reset cleaned map sensor connectors with electrical cleaner and several other ecm and pcm connections. Tomorrow my obdlink gets here and I’ll scan for codes. Also waiting for my friend to return my multimeter. I went to the miparman how to test map and it’s directions say using a drbscantool... do you have directions for using a multimeter? As of now truck runs fine and no cel lights... All tuners are unplugged right now so everything is stock...
  20. Whenever inunhooked my battery cables it reset my odometer. I read that your supposed to unhook negative first is that why but t did that?
  21. Could one of you give me a rundown on what all to test? I have fuel pressure map sensor voltage to do and what else should I be looking at?
  22. Well I’m working on it slowly but like I said I thought about getting the tuner to check fuel pressure since I wupl be getting it anyway ... what all should I test? Right now it seems like it’s running good without any tuner and the cel light went off but I’m waiting for my obdlink to arrive to check for codes.
