blk90s13
Everything posted by blk90s13
  1. Do I need to get the center hub nut off and the hub out to take the rotors out ? its a 2WD solid axle setup Rotors dont have studs or hub just like a small sedan rotors do I punch the studs out ? or its comes off separate ?
  2. Finally got some time to get around and take the manifold off got drain tube off on the ground all good to go in now Any tips on priming the turbo with oil before start up ?
  3. Really guys ? lmao You all live in Arizona now ? never saw a rusted truck ? speaking of gassers I picked up a project today to make into a second plow truck needs a motor clean body and way less rust then my diesel maybe I end up swapping it out but its a regular cab back to the diesel, today I got the top line off easy ( feed line ) bottom line one bolt came out with the extractor and the other wont budge so I tried cutting the tube off to gain more room that didn't help ! now it looks like I will take the exhaust manifold off yet again haha
  4. Yep and I am working on replacing parts little at a time I did the two front can mounts right after the plowing season was over this year. Love to buy a newer truck but I like my 02 body and 24v so much
  5. I never have that problem with a temp gauge on the oil pan I hardly ever reach 180 and that is with a block front grill on both sides, the plowing I do involves slow 1st and 2nd gear pushes at very little amounts I start at an inch and keep going till the storm stops so never stress the truck I got an AFE deep pan that I am installing last thing before the truck is ready for the snow
  6. So after driving the truck about 150 miles at most I noticed a burnt oil smell every time I would step on it, looked under hood to find out the feed line for the turbo is leaking very little oil around the fitting and the return line as well started leaking Got the truck home very slow avoiding any oil pressure build up so the lie does not explode ordered new feed and return line for the turbo and will have to change them out some time this coming week The fun time I have ahead is amazing, plow trucks make good money but they also RUST so much
  7. Any recommendation on which deep trans oil pan I should use ? I will need one after taking that trans cooler out right ?
  8. So I got it all out, I pick on the truch when ever I have time everyday I did see that the turbo drain pipe is on a hose at the motor side it was easy once I got the oil filter off so now all is out of the way manifold is off turbo attached to it and soft feed line is still attach the auto trans cooler on the side of the block which gets trans fluid and antifreeze running through it is rusted to hell and leaking anti freeze so I am taking that off and running the one cooler on the front of the radiator only will cap off the lines at the water neck ( where antifreeze feeds and returns to block under radiator ) will also change the one feed line going to the heater core its all rusted and may just break soon on me here is a couple of pictures I took of what it looks like with stuff out the way I looped the trans fluid lines under the truck
  9. The one manifold bolt that is under the turbo is super hard to get to and thats all there it left to get out, I may have to take the turbo and manifold out in one piece but the bottom drainage line gotta come off as well not sure how I Will get it off since its RUSTED bad
  10. Radiator was replaced this last fall so that is new, will add antifreeze for now and change thermostat the turbo will not come off the manifold I think I want and try to get the manifold and turbo out in one piece I need to buy a gallon of PB blaster for sure haha ! will order an exhaust manifold gasket and may also change the valve cover gasket same day, I will try and do a youtube video but cant promise as you all know how greasy one can get working on them cummins.
  11. I got a rusted one today thank got it went in my driveway in the morning before I went anyway Now did anyone do this ? the one went bad is right under the exhaust manifold and contacted the local cummisn dealer with an engine serial number etc and they said I must make sure I have three of the same size right under the exhaust manifold ? Can anyone help here ? I plan on taking the exhaust manifold off and replace all three if there is actually three but before I take anything off I like to have parts on hand.
  12. My previous BD pump lasted me since Feb 08 which XDP had on file and close to 70k miles or so.
  13. Today I was working with the truck ( hauling my enclosed landscape trailer ) and as I am driving down a back road it started bucking first thing came to mind fuel pressure The gauge was dead at Zero best thing it happened going down hill and right next to a huge empty parking lot dropped it in N and turned it off as I coasted inside the lot please don't let it be the injection pump turns out my fuel pump ( BD carter replacement ) anyway since I am in Howell NJ XDP is 20 ride away from home luckily I broke down about 10 minutes away form home fast forward an hour and half later I had a new pump installed and back in business no hard starts and the fuel pressure is much higher with the new BD replacement 20 PSI at Idle 16 at 1/4 throttle and 12-14 at WOT This is what I picked up http://www.xtremediesel.com/bd-powermax-flowliftpump.aspx I had to pick a direct replacement so I can do it in the parking lot and avoid a very expensive towing bill Which would include towing my truck home then towing my enclosed trailer + down time from my landscape work etc I am very happy with the new pump the pressure went up easy 5-6 psi
  14. P0460 P1595 P1693 fuel lever didn't work in two years cruise stopped working over 6 + month ago fuel pressure is 15 at idle and 12-14 at cruise and maybe 12 at WOT Very hard start daily changed both fuel filters one on engine and the small one pre my lift pump nothing changed I ran out of fuel 3-4 weeks ago and had to open up the injectors to get the air out and truck was fine for a week or so after that then the hard starting problem started I reset the APPS a couple of times and does not help at all
  15. I drive stick cars all my life first stick truck for me is there anything different I should be doing ? I double clutch since the clutch was changed is that right ? it just gets annoying sometimes I thought a 6 speed would be a much better trans for hauling as well I feel like I am running out of rpm so quick with the 5 speed.
  16. I got me a new truck it drives so smooth now up shifts and down shifts with ease, exhaust break is next on my list along with the 60 lbs springs I just have to make some money and decide which brand exhaust break I am getting.
  17. Pictures are in sorry it took for ever dam work everyday
  18. Really ? is it that bad bleeding a clutch on the truck ?
  19. I am going to start looking for exhaust brake as well, what brands should I look into ? and how hard is it to install the valve springs ? do I need special tools or skills ? some of them only work on stock exhaust now I have stock exhaust but lets say I want to change to aftermarket at some point do I have to get a different exhaust brake setup ?
  20. Update :Due to my crazy work hours I left the truck at my friend's repair shop and he opened the trans this morning to find the clutch in 100+ pieces and a flywheel that is slightly damaged so we ordering a flywheel and clutch kit this afternoon and hope the truck is back on the road by tomorrow I will also tack weld the 5th gear nut while the trans is out even thou I never had a problem with 5th popping out the whole time I owned the truck pictures will be here soon once I get to the shop this afternoon.
  21. I had just replaced the trans with GL-4 fluid I found it in a Napa's truck store and it was not cheap and it met the specification as per the owner manual and the local dodge dealer ( I called and they did not have any at the time ) The noise is from the front of the trans listening to it from the inside the cab, I didnt get under the truck and wont get under the truck while in gear the noise is only while its in gear I had a Nissan back in the day the clutch got so messed up that I could walk out the car with it in gear and it wont move an inch it also did a very similar noise as if the springs on the clutch are just rubbing against the fly wheel ( kinds like a little baby rattle toy noise )
  22. Update Yesterday I was doing a firewood delivery and on way home ( 2 miles from house ) the truck made a loud pop and stopped moving right after I got it out of 2nd gear and put it in 3rd as I let go the clutch I hear shatter when I release the clutch to move forward or back with no movment at all and guessing its the clutch dist gave up ? will open the trans up this weekend and see what it is expecting to see the clutch in pieces or a broken thorugh out bearing what else should I do while the trans is out ? what is the dowel pin can someone point me to the right direction ? and what is the 5th gear ball ?
  23. truck just turned 152k I have no clue if the 5th gear nut was fixed I bought it a year ago and put no more than 4k miles so far
  24. my 98 5 speed is starting to act funny between shifts wont get in gear hard to downshift and close to impossible to down shift into 3rd gear and up shift into 5th gear I must rev it up past 2k if I want it to get into 5th downshifting is a whole other story its wearing out my brakes so bad I get the truck loaded with wood for my firewood deliveries and riding the brakes all the time is not working out very well for my pockets I already flushed and filled the trans with GL-4 Napa gear oil and it did not do anything the fluid that came out was NASTY green and had almost an auto trans feel to it very watery like that's my options ? rebuild ? 6 speed swap ? how hard is that and do they have PTO ? I need a PTO for my dump body or is there some kind of linkage on the shifter that went bad ? I doubt its a linkage of any kind
