leety
  1. Thanks for all the updates. You’ve been on my mind a lot lately. It’s great to see your progress. You are truly an inspiration!!
  2. Hang in there. Listen to your body and try to give it all the rest it needs. I know that‘s hard when you’re a doer. As I have gotten older I have had to move my diet in a much healthier direction or I don’t feel as good as I want to. This situation may be a bump on that for you. Holding you in my thoughts.
  3. Awesome so happy you are back home and doing so well in the recovery process. Take good care and get the rest you need. Try not to rush it. I know it’s tempting.
  4. That's the spirit!. You've been on my mind. Thank you for sharing your struggles, vulnerability and truly bad *** warrior spirit with us all. Indeed God has more for you to share with us on this earth. From where I sit the world is a much better place with you in it. Please keep up the good fight. Somehow I know you will.
  5. You are a brave warrior!! Hang in there and keep up the great work!!
  6. Does anyone know if the RV house battery isolator is integral to the truck tow electrical system on the 2001 3500 and if so where would it be located?
  7. Fortunately corrosion is not a massive issue here. My truck has zero rust. It was started its life in Oceanside, CA was in Kingman Arizona for a bit and now back to Cali.
  8. Break back in service. Vacuums leak found and corrected. There appears to be 28 psi at the vacuum pump which exceeds the minimum of 25. Thanks everyone for all of your comments and suggestions.
  9. What component seizes? I there a way to unsieze it?
  10. Thanks for all of that great info. Yes that's why I'm taking it to a place I believe will do a comprehensive evaluation.
  11. I believe they did test the pump and found that it is not creating enough vacuum. He said he was getting a reading of 22 inhg at the pump. In the Dodge factory manual the minimum output is supposed to be 25 inhg. I will have the shop go through all the lines to make sure there are no leaks. If the pump is hosed do you know what the best replacement/rebuild option would be. The shop does transmission repairs, the just did my differential upgrade from 3.55 to 3.73 so they can rebuild things.
