kennyv
Everything posted by kennyv
  1. Hi guys/gals, I have installed a PowerPuck, boost fooler and a boost elbow. I have been adjusting the set screw on the elbow but it seems the 25 or 27 is the most boost I can get. Is 25 - 27 psi the most an HX35 will put out?Thanks. Sent from my iPhone using Tapatalk
  2. Not wanting to hijack, but I have been thinking of doing one myself and i haven't found an answer to this.......When towing a steep grade should a person use the lock up switch in 1sf and 2nd? Will the TC lock up in 1st and 2nd?Thanks and sorry to step in. Sent from my iPhone using Tapatalk
  3. How well do they work? The look good!Sent from my iPhone using Tapatalk
  4. Wash, we wish we could. Our temperature swings 40 degrees in 8 hours here. Just when we think we can wash our vehicles we'll go below 0. Then it warms up a bit, the roads get icy, then they salt, then we think we can wash then it gets cold again and the cycle continues!!! Ugh!!Yes. I travel a bit heavy. With a canopy, tool box filled and a slip tank I almost always sitting on the upper overloads and on that lower thick leave. I'm starting to think my stiff ride while loaded might improve if I install some bags and ditch that lower spring?!!!Just thinking. Sent from my iPhone using Tapatalk
  5. Question...has anyone with airbags ever removed the bottom most leaf in the pack? I'm just brainstorming ideas...Here is a photo of the leaf. Sent from my iPhone using Tapatalk
  6. Yes. I know I should! (I need to kick my own ___ into gear) I do have a pyro and fuel pressure gauge so boost and trans temp are next. Thanks again for the input. I'll wait to install the elbow until I get a proper boost gauge. I did install the the PP this afternoon and it's nice. There seems to be just a bit of difference down low but in the higher rpms it goes like crazy now!! Thanks. --- I am here: http://tapatalk.com/map.php?wsypnt Sent from my iPhone using Tapatalk
  7. Hello All I have a Scangauge. I am wondering how accurate the boost reading is compared to a mechanical gauge. .....edit.... Ok, I just had another thought......So let me backtrack a bit.....I just bought a PowerPuck and an Quadzilla boost fooler (it plugs inline with the MAP sensor). I also just made a adjustable boost elbow and I do NOT have a mechanical boost gauge. At this point I have been watching my boost pressure via my ScanGauge. As my truck is unmodified the need to watch it at this point is for curiosity and MPG reasons only. I am planning on installing the newer goods today/this weekend, but I am now wondering if the Quadzilla boost fooler will alter my ScanGauge boost reading? Thoughts?? Thanks. Ken --- I am here: http://tapatalk.com/map.php?oqlhf0
  8. Hay Dually. Thanks for the reply. I'm confused now, I thought the idea of the boost elbow was to restrict air pressure to the waste gate so it doesn't open! Wouldn't drilling the the elbow just allow more pressure to the waste gate thus allowing it to open sooner like the factory elbow?
  9. Question. If I run a boost elbow and a PowerPuck will I get a check engine light?ThanksKen
