Raffron
  1. Thank you for the reply. That link is helpful. But I have already modded the crankcase vent. I did figure out the issue. I was 1.5 gallons low of coolant. No leaks but haven't added in 2 years. Thanks again. I love this site. So I have donated to both the site fund and mikes medical bills. You guys all rock and my truck would not be as bulletproof without your time and efforts.
  2. Today it is cool out and my 2000 3500 is going almost to red on accel. And the quadzilla reads fine till 204 then reads -40. Anyone else have this issue?
  3. Thanks Mike. I will try the tune rebuild. But the level change buttons are not working even after warm-up. I have the same issue on 2 devices. Both are devices that were working. I tried the uninstall on both devices. Acting exactly the same.
  4. Hey guys it's me again. I am having a problem with the iquad app I'm having a hard time loading custom Tunes says variables have failed .I went on the default tune, now I cannot change levels. I have already deleted the app and reinstalled not sure where to go from here. Does anyone know how to contact quadzilla support? Phone#?
  5. I need to update my profile. I have dap150 10's and stock turbo. I am also having backdown pretty low in the rpms. I will try the above.......
  6. What do you mean by backdown? I am having issues with egts also.
  7. I am currently having an issue I cannot seem to clear gallon trip meter. I have tried shutting off the app, I have tried clearing the data log. any suggestions? Also. Does anyone have a VIN decoder so I know what gears I have? The paper decal in the glove box is disintegrated.
  8. I am still heaving issues with my v.2 reading 0 psi to 10 max.... but my mechanical gauge reads 5 psi cruise 35psi wot... cleaned all grounds.... about to get new batterys. 1 is loosing a cell. Drops to 11.9 over weekend. Any other ideas other than rewiring from ecm to map? Bench tested map. Still good. 5volts good...
  9. Got it. Will do
  10. Anyone have any ideas as to why my truck will go into high idle after warmup temp is reached? I hit the pedle and it goes away. Just like quad zilla. But I unplugged the quadrille and it still does the same. Weird. No changes have been made.
  11. 2000 sorry I will change that.
  12. I checked the article and the number given is a unicorn. There is 1 on ebay but looks used. Not new parts on the ol interweb thing lol. There are many cheap parts that say they work but I have had very little luck with either one. 1 popped in 10 days and this one is giving wrong readings. I am gonna try the grounds tonight. S165 looks like the one. Near the oil sending unit. Right?
