BIOHMMWV
  1. There is a little bit of wiggle with my DLD 241. If you decide to open the back of the Transfer case, you could look at one of these instead of the failure prone snap ring.: Sonnax makes an aftermarket one that is better than stock. https://www.sonnax.com/parts/1697-transfer-case-split-ring-retainer Or you could go with this: https://www.drivetrain.com/transfer-case-parts/transfer-case-saver
  2. The 47rh has computer controlled lockup and overdrive. The governor controls the valve body hydraulicly. MnTom. It sounds like internal clutch problems. How many miles are on the transmission and are they miles mainly hard miles, in town driving, towing heavy in town, etc....
  3. I'm building two 47RH transmissions and I need converters for them. But, I don't know which brand of converter to go with. Has anyone had experience with or know anyone who has had experience with PATC transmission converters? https://transmissioncenter.net/shop/8dxx-with-steel-stator-option/ They have a buy one, get one for half off special they have been running. A triple disc, billet cover, aluminum stator would be $1,000 each. Or I could go with Goerend for $1,050. Ultimate transmission has a triple disc for $1,200. A local small business by the name of Torque Converter Works also has a triple for $1,200. Torque converter Works uses a Sonnax stator, piston and cover. So, is Patc any good, or should I go with another Converter builder? Thank you for your time.
  4. The Injection pumps are interchangeable and the engine will work better with a few extra degrees, if you have the timing kit tools. Luk makes good clutches, not much more can be said about that.
  5. I think this will be the future of Diesel for the foreseeable future. https://www.trucks.com/2017/10/03/cummins-achates-advanced-tech-military-diesel-engine/ A design that dates back to around 1890.
  6. The Fred Meyer has had to replace a few injection pumps due to their crappy fuel. The best fuel is in my back yard though. He he
  7. One thing that will help with fuel economy is where you fuel up. My truck gets 2mpg less at Sinclair ( I think is the name of it. the one with the green dinosaur) vs Philipps 66 non ethanol fuel. I know Fred Meyer uses Ethanol in their diesel.
  8. Can anyone share information on how to modify the valve body on a 47rh to achieve 1st gear lock up? I am kicking around the idea of putting together an Adrino and having it control lockup in each gear along with pulling on the TV cable to delay the shift before unlocking the converter, releasing the TV cable then locking back up. I currently have manual 2nd gear lock up and have been unlocking the torque converter just before the transmission shifts to 3rd. but I need to know how soon lockup can be engaged in first without lugging the engine, or having too much of a drop in RPMs. I want to see if I can get away with not going to an aftermarket torque converter just to have the tighter stator. I'll be building a spare 47rh transmission with a 48re Stator and pump gear for increased flow. Hopefully, the pump upgrade (along with higher line pressure in the valve body) will provide enough pressure for low rpm engagement of the lockup. So, a description and picture of what needs to be done for 1st gear lockup would be appreciated.
  9. In regards to what a couple of posters said about the alternator causing troubles with the transmission. I had thought that Alternator interference only affected the 47re, not the 47RH.
  10. Stupid idea, but going back to your original idea you could but another tank across from the truck tank, you just need to rout the exhaust under the frame and to the outboard side of the frame. Then you can have a stack going through the bed. That is what I did . I'm installing a 18gallon 1988-1997 ford 18gal fuel tank where the exhaust was. A custom fuel tank would net an even higher fuel capacity. Another option is to put a 30gal Ford Bronco fuel tank where the spare tire is. Or you could get a steel transfer tank and just take it out when you don't need it.
  11. Perhaps an air to water intercooler like the 6.7 Powerstroke has. Then, you could put the radiator for the intercooler under the truck
  12. Just in case, make sure the wires going to the ABS sensor in the differential are hooked up and working. The ABS and brake lights being on also indicate a fault with the ABS sensor. Hope I'm not too far out of line.
