Standard Cab01
  1. Standard Cab01 changed their profile photo
  2. Thanks...my first diesel lol.
  3. Gotcha I was calling it TPS, what does apps mean
  4. Ok I'll get it rescanded. Apps sensor is the one by the fuel filter correct. The vp js brand new.
  5. Yes I used a mirror I'm completely positive the key is set right. I did the key trick and now there's no codes anymore, Cleaned terminals. And have gone over all fuel lines. What about tps?
  6. So this is what is going on 2001 banks exhaust, hi ram,Quadzilla xzt, RV 275 injectors brand new Bosch, fass 95 big line,. Had code1693 never found out what it was it was getting a little slow to start sometime had dead pedal sometimes and stalled sometimes. Replaced vp44 industrial injection so. Starts great but seems to idle a little rough little. Today I had dead pedal. Oh and 1693 code is gone now fuel pressure is always 17,18. Seems a little down on power would it still run if I jumped a tooth on the new vp?
  7. So this is what is going on 2001 banks exhaust, hi ram,Quadzilla xzt, RV 275 injectors brand new Bosch, fass 95 big line,. Had code1693 never found out what it was it was getting a little slow to start sometime had dead pedal sometimes and stalled sometimes. Replaced vp44 industrial injection so. Starts great but seems to idle a little rough little. Today I had dead pedal. Oh and 1693 code is gone now fuel pressure is always 17,18. Seems a little down on power would it still run if I jumped a tooth on the new vp?
  8. I reset the valves when I changed the injectors. As far as I know no air in system has a leak in the tee for the fuel gauge but I took care of that I still have a 1693 code but need to have a better scanner to find out what's causing it got rid of banks and got an xzt.
  9. Truck had 88000 miles when I got it. I've been running 2 stroke in it myself currently has 117000 miles. I've had dead peddle a few times. Happened quite often when I had the bank ottomind box the banks gauges would freeze and it wouldn't pull any boost.
  10. Ok I was wondering does a vp ever get weak or worn out. I installed a Fass 95 and a sump works great runs at 17 18 psi all the time. Installed new Bosch rv275 injectors and a Quadzilla xzt. Every once in a while it idles very slightly rough very slightly. Tonight the wife and I went out to dinner and took a drive we went a back road three the hills it had a 5 mile down hill stretch I didn't feel it but the engine died didn't realize it till I went to use the brakes and had no power. Pulled over and it started backup after a few revolutions. I have a new Vp44 just need to put it in. Thoughts anyone?
  11. I'll have to get it re scanned it seems to run good. But I've had the new vp for almost a month waiting. I love this truck.
  12. I have 1693 code and it was diagnosed going out its quit on me and died a few times. Wouldn't go over 75 but that was probably the lift pump. Does alot better with the Fass I got rid of the Banks ottomind too replaced it with a Quadzilla xzt I like it alot. In the future I'll probably get the Quad.
